trans brake button #790353
09/01/10 08:58 PM
09/01/10 08:58 PM
W.Va
fowl play Offline OP
W.Va
what are you guys or gals using for trans brake buttons?.what brand,adjustable or not,and where do you mount yours? thanks
Re: trans brake button [Re: fowl play] #790354
09/01/10 09:02 PM
09/01/10 09:02 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I use a plain old large mushroom head button mounted on the steering wheel I had it on the shifter but I find I am more consitant with it on the steering wheel
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: trans brake button [Re: fowl play] #790355
09/01/10 09:04 PM
09/01/10 09:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is what I use... the Biondo HSA-O... mounted on
the steering wheel
http://www.biondoracing.com/TransBrake.shtml
Re: trans brake button [Re: MR_P_BODY] #790356
09/01/10 09:20 PM
09/01/10 09:20 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I didn't want it on my wheel. I have one on my shifter that I only use for backing up. The other one is mounted on my "center consul" behind the shifter..
It's the button behind the toggle switch you don't see it
Re: trans brake button [Re: dusturbd340W5] #790357
09/01/10 09:42 PM
09/01/10 09:42 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I have had them in about every position... On the steering wheel has proven to me is the most consistent place. I also use the Biondo Mushroom style button, although the first one didnt work, Jegs had no problem replacing it for me...
Re: trans brake button [Re: Bob_Coomer] #790358
09/01/10 09:47 PM
09/01/10 09:47 PM
Lehigh Acres, Florida
rickstershemi Offline
Many of the racers around here use the: ReacTor Button.....but have never tried it personally.
Re: trans brake button [Re: rickstershemi] #790359
09/01/10 11:51 PM
09/01/10 11:51 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Shoot the lite release
home of the
Sox and Martin Hemi Duster
Re: trans brake button [Re: HEMIFRED] #790360
09/02/10 12:03 AM
09/02/10 12:03 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Grainger...$8 ...
5.53 @ 125 1/8th on the launch control..more left in her!
Re: trans brake button [Re: fowl play] #790361
09/02/10 06:41 PM
09/02/10 06:41 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
I have a Shoot The Lite
Re: trans brake button [Re: MR_P_BODY] #790362
09/03/10 09:19 AM
09/03/10 09:19 AM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
"Double O" Button
Re: trans brake button [Re: dc426] #790363
09/03/10 11:07 AM
09/03/10 11:07 AM
PA
ajcasini Offline
ajcasini  Offline
PA
I use the Biondo adjustable HSA-0 as well. (When I use it) I mostly footbrake but have from time to time used the button. I have it mounted by the shifter.
I have another question for you guys on this topic. Which finger or thumb do you find most consistent for release? I have only used my thumb and was pretty consistent. .011, .015, .007, .015 then had a couple .040's after that...The problem I have is when I am heavy (pressing hard on the button) I come up 40. Is it easier to use a finger as opposed to a thumb to remedy this or is just by use?
Thanks and sorry to hijack but still keeping on the TB idea.
Re: trans brake button [Re: ajcasini] #790364
09/03/10 12:29 PM
09/03/10 12:29 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
Im using a cheapo button i got from Napa and i have it mounted on the dash .This is what works best for me ,but im a wierdo .I like it on the dash cuz its outta the way and dont have to worry about accidently hitting it ...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: trans brake button [Re: The Shocker] #790365
09/03/10 05:36 PM
09/03/10 05:36 PM
, PA
sleepyhead416 Offline
, PA
JAKE BRAKE micro switch on hump.
Re: trans brake button [Re: fowl play] #790366
09/03/10 06:38 PM
09/03/10 06:38 PM
indy
E
eds dart Offline
eds dart  Offline
E
indy
Moroso,s adjustable button, adj for the least travel possible. tested several buttons that i had and this button was the most consistant releasing button. Never seen a S T L before, who makes that?
Re: trans brake button [Re: eds dart] #790367
09/03/10 08:58 PM
09/03/10 08:58 PM
Colorado
506RR Offline
506RR  Offline
Colorado
This is what I use. Works great!
http://www.reeactor.com/
