426 hemi block #789291
08/31/10 04:51 PM
08/31/10 04:51 PM
california
moparmanof85 Offline OP
california
is an rb 440 block the same as a 426 hemi block? whats the difference
Re: 426 hemi block [Re: moparmanof85] #789292
08/31/10 07:09 PM
08/31/10 07:09 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Same basic dimensions (deck hieght, etc). but the Hemi has a different head bolt pattern and cross bolted mains.
Re: 426 hemi block [Re: ScottSmith_Harms] #789293
08/31/10 09:52 PM
08/31/10 09:52 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Plus drain back holes at all 4 corners.
Re: 426 hemi block [Re: torkrules] #789294
08/31/10 10:34 PM
08/31/10 10:34 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...and the motor mount brackets on the Hemi are lower on the block & different.
Re: 426 hemi block [Re: thehemikid] #789295
08/31/10 10:52 PM
08/31/10 10:52 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
In other words the punchline to what I'm sure this is leading to?????
Yes you can build a Hemi starting with a 440 block, but you'll spend more than the cost of a real Hemi block in custom machine work and parts to make it work (no joking here!), and when you are all done you'll have a block that is not as strong as a Hemi, and that will ALWAYS be a 440 block.
