cowl hood air pans or sealing #789247
08/31/10 03:09 PM
08/31/10 03:09 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
for now I need to use this monster cowl hood.
is anything done as far as sealing the carbs ,or re routing the air in any way.
the underside
home of the
Sox and Martin Hemi Duster
Re: cowl hood air pans or sealing [Re: HEMIFRED] #789248
08/31/10 04:26 PM
08/31/10 04:26 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
I went about it a different way, I have the cowl grafted to a flat hood. It just has just enough clearance for the bug catcher. I would put a piece of sheet metal bonded to the bottom with only a small fitted cutout. Yours is lighter though.
Re: cowl hood air pans or sealing [Re: Dragula] #789249
08/31/10 04:31 PM
08/31/10 04:31 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Yes, It's not real obvious but I put a flat piece of aluminum in the opening on the underside and then made my airpan to match. If you do not have a tunnelram etc this should work. You did not say?
SRT DEMON ONE SEAT
Re: cowl hood air pans or sealing [Re: Ron Silva] #789250
08/31/10 04:32 PM
08/31/10 04:32 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
airpan
SRT DEMON ONE SEAT
Re: cowl hood air pans or sealing [Re: Ron Silva] #789251
08/31/10 06:12 PM
08/31/10 06:12 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
dragrcr97 has something I can consider. Dragula's is the next hood which I already have and gets the early P/S scoop
home of the
Re: cowl hood air pans or sealing [Re: HEMIFRED] #789252
08/31/10 06:52 PM
08/31/10 06:52 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Fred I like the looks of something along these lines. Feeds air to carb from in front of radiator and you would still exhaust hot air out of the engine compartment out the back of the cowl hood.
Getting old just means you were smarter than some and luckier than others.
Re: cowl hood air pans or sealing [Re: dannysbee] #789253
08/31/10 08:07 PM
08/31/10 08:07 PM
ohio
all spooled up Offline
ohio
did it work
Re: cowl hood air pans or sealing [Re: HEMIFRED] #789254
08/31/10 08:44 PM
08/31/10 08:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Fred I would break a piece of alum about 6" ahead of
the carb/carbs at the same height as the air horns
going to the rear of the scoop... either have it sealed
to the hood or a separate part with foam... this would
also depend on if your using entries on the carb
Re: cowl hood air pans or sealing [Re: all spooled up] #789255
08/31/10 08:49 PM
08/31/10 08:49 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
did it work
nice but this may only be around for a month or so until I add the other hood and scoop
home of the
Re: cowl hood air pans or sealing [Re: HEMIFRED] #789256
09/01/10 04:16 PM
09/01/10 04:16 PM
Baltimore,MD
lowbudget Offline
mopar addict
lowbudget  Offline
mopar addict
Baltimore,MD
I knida like the look of what you already have...Old school baby
