How do you adjust the door latch on a '67 B-body?
#789000
08/31/10 02:05 AM
08/31/10 02:05 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
1967 Satellite Hardtop. Passenger door latch works, but sorta need to slam the door. Is there a way to adjust this?
Thanks-
Re: How do you adjust the door latch on a '67 B-body?
[Re: StealthWedge67]
#789001
08/31/10 02:09 AM
08/31/10 02:09 AM
Posts: 10,135 A Red State
SNK-EYZ
A Red State
As long as the door it's self is still lined up you move the striker in the rear part of the door jam. You do that by loosening the phillips screws that secure it. If the door isn't lined up you need to adjust the door at the hinges first.
[Re: SNK-EYZ]
#789002
09/01/10 12:30 AM
09/01/10 12:30 AM
StealthWedge67
Puyallup, WA
What does the small allen-head screw do on the door side?
[Re: topside]
#789004
09/01/10 12:51 AM
09/01/10 12:51 AM
StealthWedge67
Puyallup, WA
It goes through the first click on the gear, but gets hung up before it can get to the second click. I can't figure out what its jambing on, but I can't even push it closed. The door seems aligned ht. wise, and as it jambs up, its not pushing the door up or down. I've been making micro adjustments for a while now, and cant seem to make any progress. Im further away now than when I started. I think its time to walk away and come back tomorrow with a fresh mind.
#789005
09/01/10 09:06 AM
09/01/10 09:06 AM
Posts: 5,278 San Jose, California
DennisH
Vacation
Vacation
Thanks-
Same EXACT on my 69 Coronet. Always been annoying. I will adjust the striker slightly.
[Re: belv2vert66]
#789007
09/01/10 07:11 PM
09/01/10 07:11 PM
Posts: 1,090 Saskatchewan, Canada
barracudabob
Prepare to spend a couple of hours on the door adjustment. First, with the door almost closed, try lifting the back of the door up and down. If you can, your hinges are worn, and will need bushings and pins. If there is no measurable amount of movement, proceed to the next step. Using masking tape, mark the exact location of the striker. Remove the striker, and close the door. Check for body lines lining up, gap equal all around, etc. If anything is out, you will have to remove the kick panel to get at the fasteners on the inside, and adjust. On the door side of the hinge, you can adjust for in and out, as facing the door. On the pillar side, you can adjust for and aft. Once you have everything lined up, reinstall the striker plate in the original place, and just snug the fasteners. Try closing the door. As you close the door, you will see the top of the door try to move up or down. Tap the striker lightly with a hammer, so when the door tries to close, it still lines up with the body line. Once you have the up and down right, then start on the side to side, until the door is closed and the body lines are even. Once you have everything aligned properly, tighten the striker screws. Its fiddly work, but with a little patience, you shouldn't have a problem. Hope this helps, Bob
