Holley Carb install help needed... #788746
08/30/10 09:26 PM
08/30/10 09:26 PM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
I am putting a 770 CFM Holley Ultra Street Avenger carb on my 440. Edelbrock RPM performer intake, AR Engineering throttle bracket/ with the OEM throttle pressure linkage provision.OEM Throttle cable
My question is what linkages/adapters will I need to get this hooked up? I don't want no surprises and have to order and wait on parts when the fire up comes.
I do have the Holley Kick Down linkage extender.
Anything else I might possibly need?
Re: Holley Carb install help needed... [Re: moparrulzzz] #788747
08/30/10 09:28 PM
08/30/10 09:28 PM
IA
landon1 Offline
landon1  Offline
IA
wouldn't think so...all you need is the throttle extension, a return spring/bracket (if not using stock set-up), and a carb spacer
'71 Satellite Sebring 440
Re: Holley Carb install help needed... [Re: landon1] #788748
08/30/10 09:30 PM
08/30/10 09:30 PM
Mansfield,Ohio
Mansfield,Ohio
Good deal!!! I didn't want to have to deal with missing parts when its time to fire her up!!
Been waiting 7 yrs for this!!!!!!!!!!!
