replace battery cable end #788364
08/30/10 03:17 PM
08/30/10 03:17 PM
California
70SportSatellite Offline OP
super street
super street
California
Hi,
I replaced the battery cables with reproductions that are now about 2 years old. I've noticed the positive cable end has discolored. Is there someone who can replace the end with the correct one?
Re: replace battery cable end [Re: 70SportSatellite] #788365
09/02/10 05:56 PM
09/02/10 05:56 PM
GMP440 Offline
GMP440  Offline
What about hitting some salvage yards and look for original batery terminal ends. You'll probably find some old Chrysler vehicles.
Re: replace battery cable end [Re: GMP440] #788366
09/03/10 05:42 AM
09/03/10 05:42 AM
California
super street
super street
California
Thanks, But what I would like to find is someone who nlob off the end and put a new, correct end on. I'm pretty sure this is a hot molten type process.
Re: replace battery cable end [Re: 70SportSatellite] #788367
09/03/10 08:38 AM
09/03/10 08:38 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Jurgen
There is a replacable end for the pos cable.
BUT, it's has an allen screw in the bottom of it designed to pinch the cable inside the lead.
The problem I have is the end is open allowing air inside.
Where you have air in electrical connection,you'll have condensation = eventually you'll have corrosion
Re: replace battery cable end [Re: gtx6970] #788368
09/04/10 01:19 AM
09/04/10 01:19 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Maybe try baking soda blasting and then clear coat the outside to prevent future discoloration..
Otherwise, you are stuck with buying a new one or an incorrect looking end...
