Anyone using Goodmark challenger fenders?
#788262
08/30/10 02:15 PM
08/30/10 02:15 PM
Posts: 915 near New Haven, CT
fireeng
near New Haven, CT
I may have to go this route on my 71. I was wondering if anyone had any experiences with them. Fit, look ect. Thanks for any help.
2016 Diesel Ram 3500 Mason Dump 1971 Challenger 2013 Jeep Wrangler 1979 Dodge Ram Power Wagon 400 Mini Pumper My other car is a Fire Truck.
Re: Anyone using Goodmark challenger fenders?
[Re: fireeng]
#788263
08/30/10 02:17 PM
08/30/10 02:17 PM
Posts: 15,996 RI Deep in the rust belt
chargervert
Wait,the AMD Challenger fenders are almost ready. I test fit them last week,they are close.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: chargervert]
#788264
08/30/10 06:03 PM
08/30/10 06:03 PM
fireeng
near New Haven, CT
close-close or 6 or 7 months close.
[Re: fireeng]
#788265
08/30/10 06:50 PM
08/30/10 06:50 PM
chargervert
There were only two issues with them,that required tweaking. I'd like to say within the next three months,or sooner.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: PLUM_72]
#788268
08/31/10 09:57 AM
08/31/10 09:57 AM
chargervert
No one is doing more than AMD to make sure the peices are as correct as possible. They have many different people test fitting the peices on actual cars,and are addressing the issues to insure the customer gets the best possible product,before the peices are approved for final production.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: RoadRunner]
#788270
08/31/10 11:35 AM
08/31/10 11:35 AM
chargervert
Most panels require several stamping and bending processes to complete a fender. There are also several welded peices attached to the fender. The slightest variation in one or any step of the process can effect the fitment of the part. These new cars have eliminated all of the sub attachments that the cars of the seventies had attached to the fenders. They are no more than skins,held on with plastic hardware,that are simple to produce. Things like light fixtures are now connected to the grille/bumper assemblies not the fender like back in 1970. These parts are complex to reproduce,and most are templated from parts that have been on cars for 40 years. These parts have been stressed to the car they were on,and may have had repairs done to them over the years. I have had original fenders that fit fine on one car,and wouldn't align on a different car without modifying or tweaking them. Trying to make parts that you can take out of the box and bolt on everyones 40 year old cars,that have been bumped around,rotted and improperly repaired.is a daunting task. I'm glad companies like AMD have stepped up to the plate to make quality reproduction sheetmetal parts for our cars. I remember when there were no aftermarket sheetmetal parts available for Mopars.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: Deuces-Wild]
#788272
09/01/10 02:52 PM
09/01/10 02:52 PM
chargervert
There was a guy on here saying the edge of the fender where it meets the hood on the Goodmark fenders was off quite a bit. Enough that it required cutting it and welding up a gap to straighten it.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#788273
09/01/10 02:53 PM
09/01/10 02:53 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
![](/ubbthreads/images/graemlins/wave.gif) ![](http://i137.photobucket.com/albums/q229/burdar/73%20Challenger/IMG_050312.jpg) I'm not a body man and know absolutly nothing about metal work so I'm just going by what I was told. The hood was higher than the fender in the center. This was what was done to fix it. The fender was bolted right to the inner fenders though. I know the factory used shims. Maybe shimming it would have been the right way to do it...if that would have even fixed the problem. ![](/ubbthreads/images/graemlins/shruggy.gif) Anyway...it all looks good now so I can't complain.
[Re: burdar]
#788274
09/01/10 03:05 PM
09/01/10 03:05 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Heres a couple pics of goodmark fenders where I did a little work at the top back. I also used a goodmark hood and did a little tweaking on the bow of the hood to fenders. But over all I think they fit well and look great in the end. ![](http://i123.photobucket.com/albums/o305/calschally/calschally814005.jpg) ![](http://i123.photobucket.com/albums/o305/calschally/calschally814007.jpg)
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: chargervert]
#788278
09/03/10 08:28 AM
09/03/10 08:28 AM
Challenger 1
Cincinnati, Ohio
The factory did not shim E body fenders where they bolt to the inner fenders. They put a bead of sealer down and directly bolted them to the inner fenders. They shimmed the back of the fender where it bolts to the bracket that bolts to the side of the cowl.
The 71 I took apart had shims along with seam sealer. It looked factory to me. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Challenger 1]
#788279
09/04/10 10:08 AM
09/04/10 10:08 AM
chargervert
I have had over twenty E bodies,and I never had any with shims in that area. Maybe they had an issue with your car on the assembly line,getting the fender to align,or maybe you car was repaired by a body shop sometime in its lifetime.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
