paint for black interior on '71 Demon?
#787973
08/30/10 11:35 AM
08/30/10 11:35 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
What color/shade of black should the upper door panels, upper rear 1/4 "door" panels, and the dash be in a '71 Demon? Is it a gloss or semi-flat black? Same for the doors and on the dash? Or is the dash different?
Re: paint for black interior on '71 Demon?
[Re: ademon]
#787975
08/30/10 02:19 PM
08/30/10 02:19 PM
an8sec70cuda
The hood has no scoops, no blackout treatment on the hood either. The door panels look kinda glossy now.
Is the dash the same as the door panels?
[Re: an8sec70cuda]
#787977
08/30/10 03:42 PM
08/30/10 03:42 PM
Posts: 21,456 It's a dry heat
gtx6970
It's a dry heat
plain old TX9 gloss enamel
Dash frame should be a suede black - pretty close to flat black with a very slight texture to it
[Re: ademon]
#787978
08/30/10 04:00 PM
08/30/10 04:00 PM
Posts: 101 MD
Moparlang
MD
The upper and lower doors and upper and lower quarter trim should be a lightly flattened gloss, not mega glossy. The dash in 70 is a textured suede finish, similar to organosol, but not as textured. I think 71 may not be the suede finish. It is a semi flat black similar to 70 even if it's not textured. I can try to get you the ditzler codes out of the service manual. TCP global sells the paint. If you go to their site TCPglobal.com and click "auto color library" you can get their mix codes. I'm getting ready to use their paint for my car,(Duster dash and doors in blue) looks to be good stuff!
The "mailman's son" Bad mailman!!
