Eastwood Chassis Black on K frame.. advice...please... #78784
06/23/08 02:35 PM
06/23/08 02:35 PM
Escondido, California
JonGottaDemonDad Offline OP
I have done my best to remove all grease from the k frame of the demon. There is currently a combination of paint and bare metal. Getting ready to paint it with chassis black from Eastwood and looking for some advice from guys that have experience using Eastwood chassis paint.
Should I epoxy prime, paint over bare metal or use rust converter on the k frame?
I can do any of the above just looking for best success..
Also have you sprayed on the chassis paint or did you use a brush?
Thanks for you advice...
Craig
Re: Eastwood Chassis Black on K frame.. advice...please... [Re: JonGottaDemonDad] #78785
06/23/08 02:42 PM
06/23/08 02:42 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I've used thier chassis paint a few times, and just got some more to do my Torana..I've always just used it in the spray can.
You can use it right over bare metal as well , just be sure and don't get anxoius and let it dry all the way before using the part.
If you do decide to use it over primer, they sell a primer made just for it as well.
Per Eastwood..
Works great over bare metal or Eastwood Rust Encapsulator, or Eastwood Chassis Black® Primer
Re: Eastwood Chassis Black on K frame.. advice...please... [Re: JonGottaDemonDad] #78786
06/23/08 06:29 PM
06/23/08 06:29 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
I do like using their converter underneath it. That is a little more corrosion protection. Also, there is a noticable difference btween their chassi black and Extreme Chassis Black.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Eastwood Chassis Black on K frame.. advice...please... [Re: dfsmopars] #78787
06/23/08 06:35 PM
06/23/08 06:35 PM
yea.. I did not realize the availability of the extreme chassis black until after I received the chassis black. The cost was only a few dollars more but not worth sending back and paying for shipping will use extreme next time.
how about application spray or brush?
Craig
Re: Eastwood Chassis Black on K frame.. advice...please... [Re: JonGottaDemonDad] #78788
06/23/08 07:53 PM
06/23/08 07:53 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Spray everything, whenever possible.
Careful, your character's showing!
Re: Eastwood Chassis Black on K frame.. advice...please... [Re: mopar346] #78789
06/23/08 08:48 PM
06/23/08 08:48 PM
Mississauga, Canada
KARLN Offline
KARLN  Offline
Mississauga, Canada
I used rust encapsulator as my primer and chassis black on my K-member. I used a brush and it still turned out great.
B5 Challenger T/A
Re: Eastwood Chassis Black on K frame.. advice...please... [Re: mopar346] #78790
06/23/08 08:52 PM
06/23/08 08:52 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
If you have a spray gun, spray it. On a big piece like a k-member, doubly so.
Re: Eastwood Chassis Black on K frame.. advice...please... [Re: JonGottaDemonDad] #78791
06/23/08 08:59 PM
06/23/08 08:59 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
You can use it over bare metal and old paint.It could lift around the old paint but I don't think it will. Biggest thing is, you cannot recoat. It will lift. So be sure you got all angles and surfaces the first time because if you recoat the next hour, day or week it will lift. The new stuff is not supposed to do that. Good luck.
(quote)
PS did you try pressure washing that thing at the car wash? Works pretty good with a little gasoline pre-treatment before hand.
Re: Eastwood Chassis Black on K frame.. advice...please... [Re: Challenger 1] #78792
06/24/08 01:07 PM
06/24/08 01:07 PM
so for clarification are you saying only only one coat?
There is a sticker on the top can that says wait 24 hours until applying 2nd coat.
Thanks,
Craig
Re: Eastwood Chassis Black on K frame.. advice...please... [Re: JonGottaDemonDad] #78793
06/24/08 01:41 PM
06/24/08 01:41 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I've put a couple coats on at the one time, and a couple weeks later blown in areas that I scratched and never had any problems
Re: Eastwood Chassis Black on K frame.. advice...please... [Re: OzHemi] #78794
06/24/08 04:44 PM
06/24/08 04:44 PM
Works great! Used to do it all the time at the local car wash until the owner caught me...
Got the chewin' of a lifetime but explained it away as "a little gasoline must've spilt in the back of the truck..."
He didn't buy it.
Re: Eastwood Chassis Black on K frame.. advice...please... #78795
06/24/08 04:45 PM
06/24/08 04:45 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Gas costs more then degreaser now though..
Re: Eastwood Chassis Black on K frame.. advice...please... [Re: OzHemi] #78796
06/24/08 06:37 PM
06/24/08 06:37 PM
Cincinnati, Ohio
Cincinnati, Ohio
I used a bunch of it on my last rebuild and had problems with it lifting after I applied a second coat. Then I read the can and it said not to recoat. But I'm sure the a window where you can't recoat and I'm sorry if I spread bad info.
I have recently bought some of the new ultra paint to use here soon and I remember Eastwood saying it won't lift on recoat?
