Oil pump, gasket or not?
#787857
08/30/10 09:20 AM
08/30/10 09:20 AM
Posts: 1,018 Hazlet, NJ
440Satellite
super gas
super gas
Hazlet, NJ
Hey guys, just tore down a fairly fresh 360 to inspect, re-ring and put back together. When I took it apart, there was no gasket in between the oil pump and the main cap it bolts to, but the "How to rebuild small block mopar" book I have says that there is a gasket. So do I need a gasket or not? This is on a 72 360 motor.
Butch
1972 Duster
318 4 speed
1958 392 Hemi engine
waiting to be built!!!!!
Re: Oil pump, gasket or not?
[Re: 440Satellite]
#787858
08/30/10 05:55 PM
08/30/10 05:55 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
This is a long-standing argument, the factory didn't use a gasket but most aftermarket pumps include one in the box.
I'd leave it out.
[Re: John_Kunkel]
#787859
08/30/10 06:04 PM
08/30/10 06:04 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Ive probally torn down 40 SBs.Found 1 gasket in all of those.The others had none.If the pump has one use it if not put it together.Rocky
Chrysler Firepower
[Re: John_Kunkel]
#787860
08/30/10 06:05 PM
08/30/10 06:05 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
do what ever you like and won't loose any sleep over. It won't matter one way or the other.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
