Re: M.P. STAGE 6 HEADS
[Re: MIKES_DUSTER]
#787631
08/30/10 02:00 AM
08/30/10 02:00 AM
Posts: 742 Oak Harbor, WA
Wicked49670dart
Oak Harbor, WA
I run them on my 496 70 3400 pound Dart, runs [Email]10.22@126[/Email] so far. Broke my driveshaft at the end of last year, checked motor and trans waiting on new shaft and yokes should get high 9's. These heads were ported when I brought them has had valve spring pocket work, clearence for push rods and bowl work. No flow #. Did some Nitrous tuning when the drive shaft broke...Matt http://www.youtube.com/watch?v=fjGtqFFFo6k
[Re: fishy340]
#787636
08/30/10 10:17 AM
08/30/10 10:17 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I have a set on my 499 I have only made three passes on the car but the heads I bought new and they were already completely worked over. Car ran 10.89 @ 126 mph spinning @ 3680 lb
67' charger 499 RB
10.57 at 127
[Re: J_BODY]
#787638
08/30/10 10:49 AM
08/30/10 10:49 AM
dragram440
bigfork mn
If the price is right and they have already had the work done like mine how can you pass em up.
67' charger 499 RB
10.57 at 127
[Re: MIKES_DUSTER]
#787642
08/30/10 01:00 PM
08/30/10 01:00 PM
BradH
How does the Stage 6's compare with the Edelbrocks??
IMO... - Better chamber design (heart shaped = more efficient) - Better intake port (raised runner = straighter shot at valve) - Better exhaust port (raised slightly = better peak flow) - Fully ported Stage VIs and comparably ported Edelbrock Performer RPMs can flow similar #s, but the chamber & runner of the Stage VI works better
Out of the box quality is better w/ Edelbrocks than the MP heads. If you buy stuff new, it'll cost you more initially to get the MP stuff truly "ready to run".
Like I said, "IMO"... but they've certainly worked well for me.
[Re: MIKES_DUSTER]
#787643
08/30/10 01:33 PM
08/30/10 01:33 PM
Posts: 5,080 organ
maximum entropy
organ
the mp stage 6's have some interesting design compromises. the valves are too short, the valve spring pockets are too deep, and there were some qc issues early on. the short valves and deep spring pockets restrict the port shape going into the bowl (the roof of the port is low and can't be raised). there are plenty of eddies running nines, maybe even eights, prolly.
[Re: maximum entropy]
#787644
08/30/10 01:51 PM
08/30/10 01:51 PM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
the mp stage 6's have some fatal flaws, imho. the valves are too short, the valve spring pockets are too deep, and there were some qc issues early on. the short valves and deep spring pockets restrict the port shape going into the bowl (the roof of the port is low and can't be raised). there are plenty of eddies running nines, maybe even eights, prolly.
Those issues on the Stage 6's can be addressed , they were on the heads we ran on the EM470.
[Re: BradH]
#787645
08/30/10 01:52 PM
08/30/10 01:52 PM
JohnRR
U.S.S.A.
Best would be to find a good used set that have already been fixed .
#787646
08/30/10 02:02 PM
08/30/10 02:02 PM
BradH
the mp stage 6's have some fatal flaws, imho...
I don't think "fatal flaws" is the right term. The design has limitations as a result of MP's original goal to offer a replacement head that could leverage much of the existing valve train (valves, rocker arms, springs) available already for OEM heads. Given those limitations, they work pretty well.
Those small(er) ports result in high velocity and very good throttle response, even when using moderate compression ratios and fairly large cams for true street use.
If you want big(ger) ports while keeping the basic Stage VI design, you can go w/ Edelbrock Victors or Chapman's Stage VIs.
