Re: Can 5 on 4" axles be drilled to 5 on 4.5"?
[Re: mopar346]
#78762
06/23/08 08:56 PM
06/23/08 08:56 PM
Posts: 396 California, USA
Phil Saran
California, USA
You've been given good advice. If you have the SBP axels redone, you also need to have the drums redrilled too. Runs about $125.00 to do two axels & drums.
If you have truck or "C" body axels cut and resplined, yes you do end up with stronger axels,but it does require changing over to "B" or "C" body brakes also because the axles will sit out a bit more than the "A" axels do.
Phil Saran
Parker, Colorado
[Re: MoparforLife]
#78768
06/25/08 02:53 AM
06/25/08 02:53 AM
Posts: 27,480 So Cal
autoxcuda
So Cal
My 71 Duster had the axles redrilled to the 4.5 pattern. The 4.5 pattern put the holes right at the edge of the axle, I wasn't too crazy about it.
Sheldon
Exactly why I prefer screw in studs. There is very near as much meat around the stud as with the pressed in small suds on the 4" pattern.
My Barracuda is drilled and has the screw in cap screws for lugs. Mazzolini did that for $90 in 1993. From what I know now, I'm allmost sure he subbed that out to Sutton Engineering. I've put about 50K very hard miles on them over that last 15 years!!
The rear drums are getting pretty warn though. I do run a adjustable MP brake valve though and 11.75 front disks.
My use/abuse and milage would cover about 98% of the A-body owner here though.
[Re: NFURY8]
#78769
06/25/08 10:09 AM
06/25/08 10:09 AM
Posts: 8,165 Left Coast
BobR
Left Coast
Looks like he is now giving new axles from Moser a strong consideration. Thanks for the info guys!
I would go with DR Diff over Moser and I would NEVER redrill stock flanges. For a couple of hundered bucks more you can have some much stronger axles. -Bob
[Re: JCFcuda]
#78771
06/25/08 08:23 PM
06/25/08 08:23 PM
BobR
Left Coast
Theres nothing wrong with redrilling the axles. I used bolts 4 years on the street,4,ooo miles/yr . The last year at the strip, I ran 10. 80s. 10.5 slicks.and did not have any issues. I welded the holes redrilled the holesin the axles and drums.
I guess the tech inspector never looked. If you use a locked rear or run faster than 10.99 you must use aftermarket axles for most if not all sanctioning bodies. -Bob
