Re: Master Kill Switch Wiring?
[Re: Big_Fish]
#787546
08/29/10 11:14 PM
08/29/10 11:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Cool, thanX Mr.P. I ran into a buddy who told me to double check my kill switch before I try to tech in. Sure enough it kept running and I took a look and noticed it's wired wrong. I just want a quick fix so I imagine this should be an easy method.
Yeah hook it up like your diagram on the + side then hook your charging posts up direct to the battery
[Re: Big_Fish]
#787547
08/29/10 11:27 PM
08/29/10 11:27 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
I have never liked running my alternator cable all the way to the back of the car, so I do something different than most people. I purchased a flaming river 4 post kill switch and I use the small terminals to interupt the small red MSD ignition trigger. Basically, there is a ignition 12v that goes from your ignition switch to the MSD to turn it on. Well, I simply route that wire from the ignition switch, through the battery on off switch (small terminals) and then back to the MSD. When someone flips the switch at the back; its as if someone turned your key off and disconnected the battery at the same time. As for the Alternator wire, I have always run that wire to the battery cable lug on the starter.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: RobX4406]
#787550
08/30/10 08:42 PM
08/30/10 08:42 PM
Posts: 3,031 Sac, CA
mopowers
Sac, CA
Would this work too?
No.
I know nothing about wiring so excuse my ignorance. Can you tell me why it wouldn't work?
[Re: kilroy]
#787553
09/01/10 09:14 PM
09/01/10 09:14 PM
Posts: 352 Pennsylvania, USA
Big_Fish
Pennsylvania, USA
Just wanted to take a second to thank everyone for their input on this. I made the quick wire swap like on the diagram and it's all set. Cuts off and I didn't get any extra sparks in the process ThanX Mr. P Adam
[Re: Big_Fish]
#787554
09/01/10 09:18 PM
09/01/10 09:18 PM
MR_P_BODY
Your welcome.... now get out to the track
