need carb help; holes in the throttle plates cures what
#787518
08/29/10 10:57 PM
08/29/10 10:57 PM
Posts: 1,365 elmira ny
hp340nos
elmira ny
i have a fresh built 9.7 comp 340 stroker 418 cid,idle vacuum is 11",timing set at 35*,cam is a herbert solid roller .246/.253@.050 lift is .585in/.600ex,installed at 103.5 icl.carb is a rebuilt 750 db pumper 4779-2.has a 6.5 pv.,72 f/82r jets,im trying to clean up the idle some. i set the idle mixture screws with a vacuum gauge,they ended up roughly 3/4 turn open its a 4 corner idle.do i need to crack open the secondary plated some?or should i drill holes in the throttle plate?looking for some ideas?it runs real good above idle, just little rough idling is all,thanks mike
Re: need carb help; holes in the throttle plates cures what
[Re: hp340nos]
#787519
08/29/10 11:43 PM
08/29/10 11:43 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
That might be the distributor. What do you have the lead timing at, and how much is the mechanical advance adding?
RIP Monte Smith
[Re: hp340nos]
#787525
08/30/10 01:32 PM
08/30/10 01:32 PM
Posts: 4,210 New York
polyspheric
New York
Is 23° the highest idle vacuum?
Boffin Emeritus
