need carb help; holes in the throttle plates cures what #787518
08/29/10 10:57 PM
08/29/10 10:57 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i have a fresh built 9.7 comp 340 stroker 418 cid,idle vacuum is 11",timing set at 35*,cam is a herbert solid roller .246/.253@.050 lift is .585in/.600ex,installed at 103.5 icl.carb is a rebuilt 750 db pumper 4779-2.has a 6.5 pv.,72 f/82r jets,im trying to clean up the idle some. i set the idle mixture screws with a vacuum gauge,they ended up roughly 3/4 turn open its a 4 corner idle.do i need to crack open the secondary plated some?or should i drill holes in the throttle plate?looking for some ideas?it runs real good above idle, just little rough idling is all,thanks mike
Re: need carb help; holes in the throttle plates cures what [Re: hp340nos] #787519
08/29/10 11:43 PM
08/29/10 11:43 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
That might be the distributor. What do you have the lead timing at, and how much is the mechanical advance adding?
RIP Monte Smith
Re: need carb help; holes in the throttle plates cures what [Re: hp340nos] #787520
08/29/10 11:44 PM
08/29/10 11:44 PM
P
Paul_Fancsali Offline
P
Holes will help a carb idle that has too much transfer slot open to idle better As you said you can crack the sec open too and possibly get away from the drill
Re: need carb help; holes in the throttle plates cures what [Re: Paul_Fancsali] #787521
08/29/10 11:58 PM
08/29/10 11:58 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
timing is at 23 base, total is 35, the balancer is tough to read its a bhj billet that is real shiny,i put a black mark on it when i verified tdc, i might end up puttting timing tape on it or painting it to get rid of some of the glare.
Re: need carb help; holes in the throttle plates cures what [Re: Paul_Fancsali] #787522
08/30/10 12:02 AM
08/30/10 12:02 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
Hey Mike, nice to hear you got your motor running. Any video yet? I use Don's from FBO method to set carbs, Idle and mixture adjustments. The motors I tune Idle great in park and in gear........Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: need carb help; holes in the throttle plates cures what [Re: Wicked49670dart] #787523
08/30/10 12:11 AM
08/30/10 12:11 AM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
thanks matt.no video yet i will have to figure that out next.
Re: need carb help; holes in the throttle plates cures what [Re: Wicked49670dart] #787524
08/30/10 09:45 AM
08/30/10 09:45 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
matt: mind shareing the method with other moparts members? dave
Re: need carb help; holes in the throttle plates cures what [Re: hp340nos] #787525
08/30/10 01:32 PM
08/30/10 01:32 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Is 23° the highest idle vacuum?
Boffin Emeritus
Re: need carb help; holes in the throttle plates cures what [Re: polyspheric] #787526
08/30/10 02:50 PM
08/30/10 02:50 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i did not try rotating the dist, to the highest vacuum reading, i was using the vacuum gauge to set the idle mixture screws.
Re: need carb help; holes in the throttle plates cures what [Re: hp340nos] #787527
08/30/10 06:00 PM
08/30/10 06:00 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Get the timing figured out before you do any real tuning with the carb.
Damon
Re: need carb help; holes in the throttle plates cures what [Re: mopardamo] #787528
08/30/10 06:11 PM
08/30/10 06:11 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
what should my base timing be set at ,distributor is older mp distributor ,msd6al box with blaster 2 coil.
Re: need carb help; holes in the throttle plates cures what [Re: polyspheric] #787529
08/30/10 08:10 PM
08/30/10 08:10 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Should initial be set for highest idle vacuum? Then adjust distributors mech advance to get the desired total timing?
