Cam specs #786977
08/29/10 02:05 PM
08/29/10 02:05 PM
New Kent, Va.
bobbyb Offline OP
bobbyb  Offline OP
New Kent, Va.
The guy thats putting my motor together called and said he needed info on my cam so he can degree it. What type of info is needed to degree the cam? All I have is the valve lash adjustment chart that came with it. Its a Mopar Performance 292/509 cam. I don't think he even knows its a 509. It was still in original box when I dropped it off, but he said there was no info in the box.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: Cam specs [Re: bobbyb] #786978
08/29/10 02:47 PM
08/29/10 02:47 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You have to know if it the old style P4120237 108 lobe separation or a new one P5007698 with 114 lobe separation.
The still sell the old style as well.
P4120237 I would install it 102 to 104 leaning towards 102!
P5007698 I would install it 106 to 110 intake centerline.
