8 3/4 axle fitting - Im ready for lesson 3 #78679
06/23/08 06:14 AM
06/23/08 06:14 AM
Melbourne.....Oz-land
Moparmal Offline OP
Moparmal  Offline OP
OK, so the factory 8 3/4 had an end play adjuster.
How does the bearing kit offered by Mancini get around not using this?
and is this a worthwhile conversion?
Thanks again
Re: 8 3/4 axle fitting - Im ready for lesson 3 [Re: Moparmal] #78680
06/23/08 07:20 AM
06/23/08 07:20 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
They use a sealed ball bearing assembly that doesn't need a preload/end play adjustment or cleaning and packing with a good wheel bearing grease,
Worth it - IMO - NO. The OEM tapered roller bearing is a superior bearing to the sealed ball bearing. After all servicing the axle bearings isn't something that you do every day. Maybe once in a cars life time. No big deal.
http://www.moparts.org/Tech/Archive/axle/12.html
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 8 3/4 axle fitting - Im ready for lesson 3 [Re: MoparforLife] #78681
06/23/08 07:39 AM
06/23/08 07:39 AM
Moparmal Offline OP
Moparmal  Offline OP
Thanks Don
How available is the adjuster?
....... as the housing I bought only came with one axle - left side.......
Re: 8 3/4 axle fitting - Im ready for lesson 3 [Re: Moparmal] #78682
06/23/08 07:44 AM
06/23/08 07:44 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The adjuster is not available new. I have some used ones, however.
BTW as far as I know, I have the best price on Green wheel bearings at $60 pair.
Re: 8 3/4 axle fitting - Im ready for lesson 3 [Re: DoctorDiff] #78683
06/25/08 06:45 AM
06/25/08 06:45 AM
Moparmal Offline OP
Moparmal  Offline OP
DrDiff - Ill bear that price in mind -
Are the green bearings the OEM tapered roller bearings that Don referred to?
Re: 8 3/4 axle fitting - Im ready for lesson 3 [Re: Moparmal] #78684
06/25/08 09:11 AM
06/25/08 09:11 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
DrDiff -
no , they are the replacement roller ball bearing
Re: 8 3/4 axle fitting - Im ready for lesson 3 [Re: Moparmal] #78685
06/25/08 09:11 AM
06/25/08 09:11 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Green bearings are a sealed ball design, similar to what is used in most other non C-clip rearends.
Re: 8 3/4 axle fitting - Im ready for lesson 3 [Re: DoctorDiff] #78686
06/26/08 06:51 AM
06/26/08 06:51 AM
Moparmal Offline OP
Moparmal  Offline OP
Sorry guys...but my heads hurting!!
If tapered bearings are better - why does every advert for axles I see rave about "green bearings"?
Re: 8 3/4 axle fitting - Im ready for lesson 3 [Re: Moparmal] #78687
06/26/08 09:11 AM
06/26/08 09:11 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Not sure if this will explain it better but here goes.
All cars came with a tapered bearing for the axles. It is similar to the front wheel bearings. You must adjust the preload on the bearings for them to work correctly.
Green bearings are a ball bearing style. The do not need to be adjusted. They are only 1 piece and do not have a bearing race as like the tapered bearing. They have become popular because many street guys like to swap rear ends in and out depending on highway driving or fun stoplighting.
I agree tapered are a better design, but that said I have greens in my car and so far have not had any trouble. I think both work just fine. Many friends have run greens for years. IF you plan on doing and "drifting" with it, i'd stick with tapered.
Re: 8 3/4 axle fitting - Im ready for lesson 3 [Re: Dart 340] #78688
06/26/08 10:13 AM
06/26/08 10:13 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
I think the Greens are used so much because if you buy a set of axels, they can only put Green bearings on them since the adjusters are unavailable. 7-1/4" axels used bearings similar to the Green bearings.
Re: 8 3/4 axle fitting - Im ready for lesson 3 [Re: Dart 340] #78689
06/27/08 05:14 AM
06/27/08 05:14 AM
Moparmal Offline OP
Moparmal  Offline OP
That more than explains it all - thanks again.
