A body leaf spring options #786371
08/28/10 05:57 PM
08/28/10 05:57 PM
PA
maxwedge1 Offline OP
PA
currently wading through all the leaf springs out there now for 76 duster.
my worn spring/air shock combo has to go.
i have 275/60's on 10" wheel tucked in now but i need 2 or 3" above stock ride height to retain this tire/wheel.
any recomendations on a set to just bolt on and go?? driver with occassional track visits.
Re: A body leaf spring options [Re: maxwedge1] #786372
08/28/10 07:07 PM
08/28/10 07:07 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Call ESPO and see what they have available.
It's Swifty! Swifty, you toad sucker!
Re: A body leaf spring options [Re: maxwedge1] #786373
08/28/10 10:31 PM
08/28/10 10:31 PM
AndyF Offline
AndyF  Offline
If you want the rear end jacked up for drag racing then the super stock springs are the way to go.
Re: A body leaf spring options [Re: AndyF] #786374
08/29/10 09:39 PM
08/29/10 09:39 PM
PA
PA
doesnt need to be way up...just a few inches to clear the tire.
Re: A body leaf spring options [Re: maxwedge1] #786375
08/29/10 10:37 PM
08/29/10 10:37 PM
Pgh, PA
Nino Offline
Nino  Offline
Pgh, PA
I used the SS springs from Mancini on my 68 Barracuda and it has a nice aggressive stance without being too high. I'm using a 29" tire though...
1970 Dodge Coronet 1968 Barracuda FB 1970 Duster 1974 Dart 1977 Dodge Custom Van
Re: A body leaf spring options [Re: Nino] #786376
08/29/10 10:55 PM
08/29/10 10:55 PM
Pgh, PA
Nino Offline
Nino  Offline
Pgh, PA
Here's a picture right after I put them in (I left the air shocks in for the time being -- they are inflated a little below halfway).
Re: A body leaf spring options [Re: Nino] #786377
08/30/10 05:57 PM
08/30/10 05:57 PM
PA
PA
and these springs bolt in? dont need longer hanger or bushings installed?
Re: A body leaf spring options [Re: maxwedge1] #786378
08/30/10 07:43 PM
08/30/10 07:43 PM
AndyF Offline
AndyF  Offline
May or may not bolt in, depends on which front hanger you have. A body cars came with three different bolt sizes in the front hanger. Super stock springs need the big 5/8 bolt. Order the hangers from Mancini Racing and you can get matching spring hangers at the same time. In fact, I think that Mancini has a whole package deal with new hardware, u-bolts, etc.
