68 GTX 440 auto. Has an Eddy performer intake with 800 Eddy carb. Hood clearence was fine. Installed the under hood insulation pad and it hit's the air cleaner now. Anyone else had this setup and this issue? I'm useing a K&N filter. The shorter of the 2 listed in Summit for a 440. Any one know the number for a shorter filter? Mine is 2.75 tall. I think 2.25 would give me enough room. Summit doesn't show a 2.25 in correct diameter. I'll go to a regular Fram filter if anyone knows a good part number. The hood pad is killing the pie tin. And NO i'm not gonna lose the hood pad.
