72 Roadrunner Brake Pedal Problems #786256
08/28/10 01:23 PM
08/28/10 01:23 PM
Easton, Kansas
Moparmedic440 Offline OP
Easton, Kansas
When ever I depress the brake on my 72 Roadrunner I have to put my foot under the pedal and pull it up It's not much 1/2" or less or the brakes drag. Is there a adjustment to correct this problem. Thank You
Re: 72 Roadrunner Brake Pedal Problems [Re: Moparmedic440] #786257
08/28/10 04:08 PM
08/28/10 04:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you have to pull the pedal up and it is free moving then you have other problems. Th pedal return should be caused by the master cylinder. If the master doesn't push the pdeal back then it's probably bad if the brakes drag as you say. Is this a manual or power brake car? Have you tried lubing the pedal pivot points?
Re: 72 Roadrunner Brake Pedal Problems [Re: Moparmedic440] #786258
08/28/10 05:49 PM
08/28/10 05:49 PM
pa
73roadbird Offline
73roadbird  Offline
pa
Just posted the same problem with my dart. Ok 3 years ago, now replaced some parts and ready to go cruising and now this issue, always something I guess.
Re: 72 Roadrunner Brake Pedal Problems [Re: 73roadbird] #786259
08/28/10 07:31 PM
08/28/10 07:31 PM
indiana
generallee6901 Offline
indiana
Had the same problem on my charger with manual brakes.I do not drive it often enough and the piston was corroding up in the bore and would not let it return all the way.Put a new one on and it is fine now.
