Re: industrial 413
[Re: moparmanof85]
#786107
08/28/10 01:42 AM
08/28/10 01:42 AM
Posts: 34,928 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Seriously ..
Find something else to work with
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: industrial 413
[Re: dOoC]
#786111
08/28/10 02:40 AM
08/28/10 02:40 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The short comeings can be remidied by replaceing pretty much every part of the engine. Heads flow worse than a 360 head and bigger valves and porting are not gonna help much. The cam is obviously very puny, It has very low compression so it needs new pistons witch by the time you buy custom pistons you can buy off the shelf 440 pistons and a 440 block for the same dollars that will make more power. The only things I would re-use would be a crank, rods and mabey a few bolts Hard to address one critical area and see much gain on an engine that has that many short comeings for building HP. It can be built to make a lot of HP even with just 413 inches but it will cost more than makeing more power from a 440 would. It would all look the same from the outside when done too.
Re: industrial 413
[Re: dOoC]
#786113
08/28/10 02:57 AM
08/28/10 02:57 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
A POS ?
Come on now .. that moder is what made Mopar KING of the RV and "dump-truck" market for years !!
It has some short-comings .. but that can be remedied.
Junk
IMO
Re: industrial 413
[Re: dOoC]
#786115
08/28/10 03:29 AM
08/28/10 03:29 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
WHATEVER Thats a POS for a starting point for any project Argue with someone who cares
JUNK
Re: industrial 413
[Re: moparmanof85]
#786118
08/28/10 08:25 AM
08/28/10 08:25 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
The same as you'd do with a ny other engine..cam,exhaust and so on.I don't know what the specs are on the 413 cam,but maybe something like a Comp Cams old hi energy or the stock 440 cam for starters...
Re: industrial 413
[Re: Chris2581]
#786119
08/28/10 11:21 AM
08/28/10 11:21 AM
HotRodDave
Kalispell Mt.
In that case slide a 440 short block under it, that will give you another 50lbs TQ even if it was a cast crank motor home short block.
Re: industrial 413
[Re: bigdad]
#786120
08/28/10 12:40 PM
08/28/10 12:40 PM
Posts: 30,454 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
...and YET .. looky-who is ARGUING !!
And to the OP ... this topic would be BESTer in the "general" section .. the ole indust 413 is in no-way a race-only motor.
Re: industrial 413
[Re: DAK512]
#786121
08/28/10 02:44 PM
08/28/10 02:44 PM
Posts: 242 Upland, California
Spode
Upland, California
OK There is the problem you posted a question, on a race site that looked like you wanted a race motor. Now that we know what you are really after, you should get the answers you wanted.
You posted the question in the wrong section.
Re: industrial 413
[Re: Chris2581]
#786122
08/28/10 08:22 PM
08/28/10 08:22 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Unfortunately, there aren't any new cam cores for the 413 Industrial motors.
