Page 2 of 3 1 2 3
Re: 6-way seat track braces for 71 B-body [Re: Alaskan_TA] #786060
08/31/10 11:08 PM
08/31/10 11:08 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Anybody got a 1971 B-Body FSM that can look for a similar diagram to the one I posted?
May as well cover the 1971 E-Body too while we are at it.
The '71 FSM shows the same thing you posted. The figure is labled "Challenger" though. This manual covers all Dodge cars.
Re: 6-way seat track braces for 71 B-body [Re: ScottSmith_Harms] #786061
08/31/10 11:48 PM
08/31/10 11:48 PM
SF Bay Area, CA
charger440sixpak Offline OP
SF Bay Area, CA
I can tell you first hand as I was involved in making the reproductions you pictured (In fact I took that very picture)
Scott, my apologies for not including the appropriate credit, I saved your photo a long time ago and didn't recall where I'd found it.
and though I haven't seen every original set, I've seen at least a couple dozen that were fresh off the cars (70 & 71 E-body cars) and none of them had the welded on spacers.
That would support my theory the spacers were only on the B-bodies, maybe only the Charger? I know I've seen a couple other B's with 6-ways (a RR and a GTX) but I've no idea whether the same braces were used.
Nick, I'll check my floor pan and see if I have the plates on the underside of the floor pan. I know the ones on the top side are there.
Re: 6-way seat track braces for 71 B-body [Re: charger440sixpak] #786062
08/31/10 11:56 PM
08/31/10 11:56 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Problem is that the '70 Challenger service manual shows the spacers.
Re: 6-way seat track braces for 71 B-body [Re: NicksGarage] #786063
09/01/10 01:12 AM
09/01/10 01:12 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Ok, image below is from the 1970-71 parts book.
No mention of spacers with the B,J models (Barracuda / Challenger) although the FSM clearly shows them.
Note the highlighted section for the B-body crossmembers says "w/spacers". (W/' is 'with')
So to me, this seems to indicate welded spacers for the B-bodies, likely because the floors did not have the cup in place that the e-bodies had to help hold them in place.
Re: 6-way seat track braces for 71 B-body [Re: Alaskan_TA] #786064
09/01/10 01:43 AM
09/01/10 01:43 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
I was just looking at the same thing. Right above your highlighted section are more '71 B-body ones that have the same part numbers as the E-bodies.
When you did the one for your web site, did you have spacers?
Re: 6-way seat track braces for 71 B-body [Re: NicksGarage] #786065
09/01/10 01:46 AM
09/01/10 01:46 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I was not aware they existed until you asked me to look at this thread.
Re: 6-way seat track braces for 71 B-body [Re: Alaskan_TA] #786066
09/01/10 02:15 AM
09/01/10 02:15 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Anyone have a copy of the bulletin announcing the cancellation of the 6-way seat option in December 1970? I believe it mentions some other option as well.
Re: 6-way seat track braces for 71 B-body [Re: NicksGarage] #786067
09/01/10 02:36 AM
09/01/10 02:36 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
You don't need to appologize, I was just letting you know where the pic originated.....Although "Some people" continue using Dr.'d versions of my original photos to promote the items I no longer sell (even though I politely requested that they discontinue doing so and that they set up and take thier own photos).
Re: 6-way seat track braces for 71 B-body [Re: ScottSmith_Harms] #786068
09/01/10 08:12 AM
09/01/10 08:12 AM
WI
RestoRick Offline
RestoRick  Offline
WI
If you're referring to me, I've had no such request...
Re: 6-way seat track braces for 71 B-body [Re: RestoRick] #786069
09/01/10 09:47 AM
09/01/10 09:47 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No Rick, not you directly, seems that you weren't told, about it, it's all good between us.
Re: 6-way seat track braces for 71 B-body [Re: ScottSmith_Harms] #786070
09/01/10 12:41 PM
09/01/10 12:41 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
I assume these repro seat braces do not come with the spacers. Is that the case?
Re: 6-way seat track braces for 71 B-body [Re: NicksGarage] #786071
09/01/10 10:31 PM
09/01/10 10:31 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Yes, no spacers with the repro's.
I have dimensions for them, but I haven't gotten around to having some made.
Rick
Re: 6-way seat track braces for 71 B-body [Re: charger440sixpak] #786072
09/02/10 05:57 PM
09/02/10 05:57 PM
Chilly Northern, Minn.
71 Charger R/T Offline
My car ('71 Charger R/T) is opted with the six way (all original still) and has the welded spacers on the brackets with no plates below but plates above floor pan.
Re: 6-way seat track braces for 71 B-body [Re: 71 Charger R/T] #786073
09/02/10 06:57 PM
09/02/10 06:57 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
My 1970 'Cuda built in LA have them and they are not welded on..........
Admiration For Multiple Carburetor Vehicles...
Re: 6-way seat track braces for 71 B-body [Re: 71 Charger R/T] #786074
09/02/10 08:39 PM
09/02/10 08:39 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
What SPD & plant was your Charger R/T assembled?
Re: 6-way seat track braces for 71 B-body [Re: 71 Charger R/T] #786075
09/03/10 10:16 PM
09/03/10 10:16 PM
Ohio
tak Offline
tak  Offline
Ohio
The Roadrunners/GTX/Sats also have the spacers. The E bodies have the seat reinforcement plate on the underside of car so the spacer isn't needed and the b-bodies with bucket seats have the reinforcement plate top side under the carpet, reason for spacer.
Re: 6-way seat track braces for 71 B-body [Re: tak] #786076
09/04/10 02:01 AM
09/04/10 02:01 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
At least some E-bodies used the spacers anyway. The ones I have came from a '70 Barracuda.
Re: 6-way seat track braces for 71 B-body [Re: 6bblgt] #786077
09/06/10 10:33 PM
09/06/10 10:33 PM
The plant it was built at was Lynch Road, Mi.
By SPD I assume you mean specific production date?....if so, Jan 29 1971
Re: 6-way seat track braces for 71 B-body [Re: 71 Charger R/T] #786078
09/07/10 01:02 AM
09/07/10 01:02 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Interesting, they were supposedly removed from the options list in December of 1970. Was your car ordered? Maybe it slipped in under the wire. Never know with Chrysler.
Re: 6-way seat track braces for 71 B-body [Re: NicksGarage] #786079
09/07/10 11:39 AM
09/07/10 11:39 AM
SF Bay Area, CA
SF Bay Area, CA
This would be my educated guess - when the call was made to drop the 6-way manual adj. seat option, the existing orders calling for the option were tallied and some extra's added for a final order from the vendor. As the cars with the 6-way seats ordered came up for production, the 6-way seats from the final order were installed. This might also explain why the extra "6-WAY SEAT" appears on the bottom of the broadcast sheet.
Is there any way to decipher the order date from the order number? Not the SPD but the actual date a salesperson at a dealership took/placed the order? I think that's the key...
Page 2 of 3 1 2 3
