20/50 Oil VS 10/30 Oil & Rhodes Lifters. Questions? #78562
06/22/08 09:34 PM
06/22/08 09:34 PM
Manistee, Michigan.
High Impact Offline OP
Manistee, Michigan.
I have a built 383 with the old school MP 108CL 284/484 cam in it. I installed the Rhodes lifters in it to help with vacuum for the power brakes. (The vacuum is about 10-11 at idle and 7-8 in gear) I;ve run 20-50 oil since it was broke in but someone said to try 10-30 instead so that the lifers will bleed down quicker. So, I did that today and went to start the motor and it would'nt idle.............Hmmmmmmmmmmm. I ended up cranking up the idle screw alittle and Im alittle confused that the car now runs diffrent........Not sure if its better but it runs diffrent.
Did I do the right thing?
Re: 20/50 Oil VS 10/30 Oil & Rhodes Lifters. Questions? [Re: High Impact] #78563
06/22/08 10:10 PM
06/22/08 10:10 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
actually with thinner oil you will build up oil pressure faster so the lifters pump up faster and stay pumped up at a lower rpm.
my hemi has rhodes lifters and it runs better with 20W50 oil than with 15W40 oil.
perception is 90% of reality
Re: 20/50 Oil VS 10/30 Oil & Rhodes Lifters. Questions? [Re: Mr T2U] #78564
06/23/08 09:44 AM
06/23/08 09:44 AM
Manistee, Michigan.
Manistee, Michigan.
