1971 340 valve covers #785592
08/27/10 02:30 PM
08/27/10 02:30 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
thanks to chrisf's picture. I think I found a match for valve covers on my car. The numbers say 2946079 99201
and 2536926 FK2-117
Can anyone confirm these are correct for 71 340?
Thank you
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: 1971 340 valve covers [Re: fireeng] #785593
08/27/10 04:08 PM
08/27/10 04:08 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Where'd you get that photo? (looks familiar?). Anyway, yes, those are correct for a 71 340, as are the other items you see on that engine. However, the later production 71 340's were painted blue (started in approx. March of 1971). some if not all of these engines had a different passenger side VC, it lacked the large center tab having a small tab in it's place like you see on the two far ends.
Re: 1971 340 valve covers [Re: ScottSmith_Harms] #785594
08/27/10 05:05 PM
08/27/10 05:05 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
Scott, again thank you for your knowledge. Chrisf posted that pic in my other thread looking for 71 info. It did indeed help me find a match.
1971 Challenger
2013 Jeep Wrangler
Re: 1971 340 valve covers [Re: fireeng] #785595
08/27/10 06:58 PM
08/27/10 06:58 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I asked because I'm pretty sure that's an engine I once owned
Re: 1971 340 valve covers [Re: ScottSmith_Harms] #785596
08/27/10 09:29 PM
08/27/10 09:29 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
since i bought my demon Scott i have been saving every picture i find thats detail related for my resto the file is 547MB
so yes, i probably stole it from you
Re: 1971 340 valve covers [Re: chrisf] #785597
01/15/12 06:37 PM
01/15/12 06:37 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
BTW, for all of you looking to find "correct" 71 valve covers keep in mind that there were at least 2 styles used, one style had the large wire loom tab on the passenger side, the other used the same individual wire tab in the center as used on the two ends. So far my data shows that the engines painted blue and installed in later built 71's had the small center tag variety (cars generally built after April 1971.......And yes,a couple of exceptions have surfaced.
Re: 1971 340 valve covers [Re: ScottSmith_Harms] #785598
01/15/12 06:46 PM
01/15/12 06:46 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: 1971 340 valve covers [Re: ScottSmith_Harms] #785599
01/15/12 06:47 PM
01/15/12 06:47 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The carb and a bunch or small accessory items have been replaced but all of the blue painted items on this engine are factory applied. This is a June 71 Built 340 Duster.
Re: 1971 340 valve covers [Re: ScottSmith_Harms] #785600
01/15/12 06:50 PM
01/15/12 06:50 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I have a extra pair of the late 71 with the small tab. never seen one with the large tab, where the large tab LA cars maybe?
Re: 1971 340 valve covers [Re: ademon] #785601
01/15/12 07:11 PM
01/15/12 07:11 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
Scott
Thanks for the added info. This thread bumped up cause I linked it for someone in the tech section. My shop is just now assembling the final details on my engine for install later this month. I am going to run that later model thermo quad you gave me info on.
1971 Challenger
2013 Jeep Wrangler
Re: 1971 340 valve covers [Re: ademon] #785602
01/15/12 07:47 PM
01/15/12 07:47 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No, the larger tabs were on the engines painted orange from all plants. I have seen ONE lone set of small tabs that were originally painted orange but I could not confirm what they came off of, could have been either 70 or 71's. I have never seen any original 71 340's painted blue with the large tab, I believe that changed when the color changed.
Re: 1971 340 valve covers [Re: ScottSmith_Harms] #785603
01/15/12 08:02 PM
01/15/12 08:02 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
What years used the ones with the bulge/hump in the center where the breather cap and PCV valve goes?
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: 1971 340 valve covers [Re: 471Magnum] #785604
01/15/12 08:10 PM
01/15/12 08:10 PM
Texas
Ron69rr Offline
Ron69rr  Offline
Texas
I found his picture of a 318 painted blue with the 4 post plug wire loom on the passenger side.
Re: 1971 340 valve covers [Re: 471Magnum] #785605
01/15/12 08:49 PM
01/15/12 08:49 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
70 and up used the "hump" style breather design
Re: 1971 340 valve covers [Re: ScottSmith_Harms] #785606
01/15/12 09:48 PM
01/15/12 09:48 PM
MD
floyd Offline
floyd  Offline
MD
Re: 1971 340 valve covers [Re: floyd] #785607
01/15/12 10:05 PM
01/15/12 10:05 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Which one is that Floyd? SPD, of car? Small tab/large tab?
Re: 1971 340 valve covers [Re: ScottSmith_Harms] #785608
01/15/12 10:25 PM
01/15/12 10:25 PM
MD
floyd Offline
floyd  Offline
MD
Sorry Scott - I don't have much info on this car. I grabbed a bunch of pics when it was listed on eBay several years ago. The car is in OH. It's come up before here on Moparts and another member who had seen the car in person said it appeared to be very original.
Re: 1971 340 valve covers [Re: floyd] #785609
01/15/12 10:26 PM
01/15/12 10:26 PM
MD
floyd Offline
floyd  Offline
MD
one more
Re: 1971 340 valve covers [Re: floyd] #785610
01/15/12 10:32 PM
01/15/12 10:32 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Looks like a small tab version which would be consistant with others I've seen built after April of 71. Another note, I question the originallity of blue paint overspray on the choke assembly and idle stop solenoid, it has likely had some paint touchup or a complete repaint at some point in it's past.
Re: 1971 340 valve covers [Re: ScottSmith_Harms] #785611
01/15/12 10:49 PM
01/15/12 10:49 PM
MD
floyd Offline
floyd  Offline
MD
Yep - it looks like there's some overspray on the solenoid as well.
