Run a 727 with blocked cooling lines? #785577
08/27/10 01:48 PM
08/27/10 01:48 PM
Marshall, Texas
royt440 Offline OP
royt440  Offline OP
Marshall, Texas
During engine break-in on a test stand, would it hurt to have the transmission cooling lines blocked? There will be no load on the transmission. It's really just on so I can start the engine with the starter.
Roy
Re: Run a 727 with blocked cooling lines? [Re: royt440] #785578
08/27/10 01:52 PM
08/27/10 01:52 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
Roy
Blocked- yes.
Tied together in a loop- no problem
Re: Run a 727 with blocked cooling lines? [Re: Pat_Whalen] #785579
08/27/10 02:22 PM
08/27/10 02:22 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Roy
Blocked- absolutely .
Re: Run a 727 with blocked cooling lines? [Re: gtx6970] #785580
08/27/10 02:28 PM
08/27/10 02:28 PM
Marshall, Texas
royt440 Offline OP
royt440  Offline OP
Marshall, Texas
thanks guys, I'll get a loop on it.
Re: Run a 727 with blocked cooling lines? [Re: royt440] #785581
08/27/10 03:04 PM
08/27/10 03:04 PM
scratchnfotraction Offline
should NOT pump fluid in park unless it has a mod done to it so it pumps in park
bu yes a rubber hose loop is the way to go
I would also have fluid in the tranz so it not low and run it in N so it is luricating the inside
