wheel adapters #784878
08/26/10 05:15 PM
08/26/10 05:15 PM
Poplar Bluff, Missouri
partfiler69 Offline OP
Still Wondering
Still Wondering
Does anybody know where I can get a set of wheel adapters? I bought a set of rallye wheels that came off a 70 dart, and I assumed they were SBP, but they're not, and I don't want to swap over to discs, I just wanna bolt these on and go.
Back from hiatus
Re: wheel adapters [Re: partfiler69] #784879
08/26/10 05:22 PM
08/26/10 05:22 PM
N. Dak.
RareTA Offline
super street
RareTA  Offline
super street
N. Dak.
Just Google wheel adapters and you will find a ton of them.
'09 Challenger R/T '70 Challenger T/A 340 6Pak and Auto I was born with nothing and I still have most of it left!
Re: wheel adapters [Re: partfiler69] #784880
08/26/10 11:07 PM
08/26/10 11:07 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've heard and seen more tales of woe with wheel adapters than I care to recount, either swap over to the larger bolt pattern, or have a machine shop redrill your hubs and axles drums( more expensive), or spring for the correct SBP wheels
Re: wheel adapters [Re: partfiler69] #784881
08/26/10 11:20 PM
08/26/10 11:20 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
I have a nice set of Vintage Mr. Gasket ones drilled 7/16 and have 1/2 inch studs..PM if interested...
Some I have heard where they failed were 7/16 drilled and had 7/16 studs for the big bolt wheels which are 1/2 studs.....
Re: wheel adapters [Re: QuickBpBp] #784882
08/26/10 11:40 PM
08/26/10 11:40 PM
United states wisconsin
bigblockbryan Offline
Stay away from them I bought some and they just are not worth it
Re: wheel adapters [Re: bigblockbryan] #784883
08/27/10 01:04 PM
08/27/10 01:04 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
I'd go with some good billet aluminum or steel adaptors that you can find on the web for around $75-$125.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: wheel adapters [Re: partfiler69] #784884
08/27/10 02:57 PM
08/27/10 02:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Why not just find a set of small bolt pattern wheels ? did the seller try to pass them off as small bolt pattern or did you just assume they were ?
Re: wheel adapters [Re: bigblockbryan] #784885
08/27/10 03:44 PM
08/27/10 03:44 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Best advise.
Re: wheel adapters [Re: JohnRR] #784886
08/31/10 09:31 PM
08/31/10 09:31 PM
Still Wondering
Still Wondering
The craigslist ad said they were off a 1970 Dart, so I assumed they were SBP. IMO, they are hard to tell with the sombreros. But nobody's fault, but my own.
Back from hiatus
