poly 318 and new hemi headers the same? #78483
06/22/08 08:23 PM
06/22/08 08:23 PM
Andrewh Offline OP
Andrewh  Offline OP
Maybe not exactly, but I was staring at the picture of headers for the new hemi and noticed the spacing was even like the old poly.
Just wondering if anyone every checked to see if they would bolt up.
Re: poly 318 and new hemi headers the same? [Re: Andrewh] #78484
06/22/08 10:28 PM
06/22/08 10:28 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
They will not just bolt up but they are close enough you could probably cut off the flanges and weld on some flanges from the other motor. You will need to re-weld them at the proper angle because the mounting surface is more perpendicular on the poly than the new hemi.
Re: poly 318 and new hemi headers the same? [Re: HotRodDave] #78485
06/23/08 12:17 AM
06/23/08 12:17 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
FYI the spacing on the sb ford is close too.
Re: poly 318 and new hemi headers the same? [Re: 65rbdodge] #78486
06/23/08 10:15 AM
06/23/08 10:15 AM
Andrewh Offline OP
Andrewh  Offline OP
Just looked close then. Thought it might be a cheaper alternative than the spitfire or TTI.
Thanks.
