what Spark Plug should i run??? 360 Mild Cam/w headers #78465
06/22/08 08:00 PM
06/22/08 08:00 PM
Anonymous OP
Anonymous OP
went in to parts store to pick up some new spark plugs, and i thought i was in school...the sales person gave me his 2 cents and then some!!!
he told me because im running a mild cam, headers, 650 carb., i should use a diff. spark plug! , now all what they had in the store was autolite(cheap sh!t)computer calls for Autolite 65, he told me to run Autolite 64, claims to be a better plug for my app! is this true or he is just lost in another planet??
Re: what Spark Plug should i run??? 360 Mild Cam/w headers #78466
06/22/08 08:03 PM
06/22/08 08:03 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
3923 autolite . the champ Je11y's are fer the big stuff. who do you think you are? mister big stuff....
raelians are from israelia?
Re: what Spark Plug should i run??? 360 Mild Cam/w headers [Re: mark7171] #78467
06/22/08 08:10 PM
06/22/08 08:10 PM
Anonymous OP
Anonymous OP
3923 autolite
now a diff. part #??? now who is right here
Re: what Spark Plug should i run??? 360 Mild Cam/w headers #78468
06/22/08 08:13 PM
06/22/08 08:13 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
the 65's are symbolically correct.
Re: what Spark Plug should i run??? 360 Mild Cam/w head #78469
06/22/08 08:15 PM
06/22/08 08:15 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
RN12YC Champion plugs. Have Champions for eons and not had a problem with them. They Have been the OEM plugs on Mopars for as long as I can remember and I have been involve with Mopars for 40 + years.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: what Spark Plug should i run??? 360 Mild Cam/w head [Re: MoparforLife] #78470
06/22/08 08:18 PM
06/22/08 08:18 PM
md
mopars4ever Offline
mopars4ever  Offline
md
64 is a little colder plug then the 65. I use 64`s with no problems. Champions worked well for me too. Mike
Re: what Spark Plug should i run??? 360 Mild Cam/w headers [Re: mark7171] #78471
06/22/08 08:18 PM
06/22/08 08:18 PM
Anonymous OP
Anonymous OP
just wondering why he said 64 anyone knows why??
Re: what Spark Plug should i run??? 360 Mild Cam/w head #78472
06/22/08 08:21 PM
06/22/08 08:21 PM
md
mopars4ever Offline
mopars4ever  Offline
md
The 65 is close to a N14Y champion which is a hotter plug. Performance engines usually need a colder range plug. From what I remember a 64 plug is closer to a N12Y champion. Mike
Re: what Spark Plug should i run??? 360 Mild Cam/w head [Re: mopars4ever] #78473
06/22/08 08:22 PM
06/22/08 08:22 PM
Anonymous OP
Anonymous OP
what does that mean,by a colder plug.. does i have to do with my mods on the engine..
as for the champion plugs, i think im going thata way!they been out there for ever!
Re: what Spark Plug should i run??? 360 Mild Cam/w headers #78474
06/22/08 08:23 PM
06/22/08 08:23 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
because your car is cooler..
Re: what Spark Plug should i run??? 360 Mild Cam/w head [Re: mopars4ever] #78475
06/22/08 08:24 PM
06/22/08 08:24 PM
Anonymous OP
Anonymous OP
thanks i got it, sorry im a little slow on typing , alway one question behind!
Re: what Spark Plug should i run??? 360 Mild Cam/w headers [Re: mark7171] #78476
06/22/08 08:25 PM
06/22/08 08:25 PM
Anonymous OP
Anonymous OP
THATS RIGHT!!!! LOL
Re: what Spark Plug should i run??? 360 Mild Cam/w head #78477
06/22/08 08:42 PM
06/22/08 08:42 PM
fort worth,tx
txterry2 Offline
super gas
txterry2  Offline
super gas
fort worth,tx
I ran one heat range lower for a while to see what it looked like in one cylinder for a test.
Re: what Spark Plug should i run??? 360 Mild Cam/w head [Re: txterry2] #78478
06/22/08 08:55 PM
06/22/08 08:55 PM
Kansas
racincuda Offline
racincuda  Offline
Kansas
I don't kno what you mean by mild but if it runs on pump gas with a full exh system (street car)and no overheating issues then I would probably just run a stock 360 plug. Colder plugs foul easier so if it's not needed then why bother ???
If this is a race only car go ahead and try a colder plug. some like to tune for different tracks /track conditions by changing plugs & adjusting timing.
It"s your call, really
Re: what Spark Plug should i run??? 360 Mild Cam/w head #78479
06/22/08 10:55 PM
06/22/08 10:55 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
A colder plug dissipates heat at a faster rate which makes it run cooler. A hotter plug dissipates heat slower so it runs hotter.
I have had bad luck with champions and will never run them again. Autolite only for me.
Re: what Spark Plug should i run??? 360 Mild Cam/w headers #78480
06/23/08 09:27 AM
06/23/08 09:27 AM
pittsburgh,Pa.
mikepar Offline
mikepar  Offline
pittsburgh,Pa.
anew plug on the market is the E-3 diamond fire
spodda save gas and give a cupilla horse power gain, about 5 depending on the application this i did sea this demoed on a dyno on tv if you believe everything you sea on TV
Re: what Spark Plug should i run??? 360 Mild Cam/w headers #78481
06/23/08 12:06 PM
06/23/08 12:06 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
The heat range of the plug is an indicator of how quickly the plug cools off between firings. A colder heat range will cool off quicker than a hotter range.
You want to run as hot a plug as the engine can stand, this ensures that deposits get burnt off so the engine will run well for a long time. To hot a plug and it can cause detonation and the tips will erode away faster.
The stock heat range is just fine, one heat range cooler will not make a difference if the engine was running well with the stock range.
The 3923 mentioned above is one heat range cooler, a 3924 is stock. These plugs have a 5/8" hex for the socket (but are the same other wise) instead of the 13/16" of the 64 or 65. The 5/8" hex makes it easier getting the plug past header tubes, the 3924 plug is what comes stock in 3.9/5.2/5.9 liter magnum engines.
I typically use Autolites simply because the local Walmart has them and it saves me a few miles of driving to a parts store to get something else. I would avoid the gimik plugs like E3 and Splitfires, once the voltage potential builds up enough to jump a spark you only get one regardless of how many or the configuration of the ground electrode.
The platinum and an iridium plugs last longer than a conventional plug and that is why they exist, not to make more power or increase mileage. They were developed so the manufacturers could extend plug changes to 100,000 miles.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: what Spark Plug should i run??? 360 Mild Cam/w head [Re: MoparforLife] #78482
06/23/08 02:21 PM
06/23/08 02:21 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I've used RN12YC and RN14YC plugs on my 318's and 360's with no problems.
2017 Grand Cherokee Overland
