what Spark Plug should i run??? 360 Mild Cam/w headers
#78465
06/22/08 08:00 PM
06/22/08 08:00 PM
went in to parts store to pick up some new spark plugs, and i thought i was in school...the sales person gave me his 2 cents and then some!!!
he told me because im running a mild cam, headers, 650 carb., i should use a diff. spark plug! , now all what they had in the store was autolite(cheap sh!t)computer calls for Autolite 65, he told me to run Autolite 64, claims to be a better plug for my app! is this true or he is just lost in another planet??
Re: what Spark Plug should i run??? 360 Mild Cam/w headers
#78466
06/22/08 08:03 PM
06/22/08 08:03 PM
Posts: 1,261 ILL
mark7171
ILL
3923 autolite . the champ Je11y's are fer the big stuff. who do you think you are? mister big stuff....
raelians are from israelia?
[Re: mark7171]
#78467
06/22/08 08:10 PM
06/22/08 08:10 PM
3923 autolite
now a diff. part #??? now who is right here
#78469
06/22/08 08:15 PM
06/22/08 08:15 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
RN12YC Champion plugs. Have Champions for eons and not had a problem with them. They Have been the OEM plugs on Mopars for as long as I can remember and I have been involve with Mopars for 40 + years.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: mark7171]
#78471
06/22/08 08:18 PM
06/22/08 08:18 PM
the 65's are symbolically correct.
just wondering why he said 64 anyone knows why??
#78472
06/22/08 08:21 PM
06/22/08 08:21 PM
Posts: 13,580 md
mopars4ever
md
The 65 is close to a N14Y champion which is a hotter plug. Performance engines usually need a colder range plug. From what I remember a 64 plug is closer to a N12Y champion. Mike
[Re: mopars4ever]
#78473
06/22/08 08:22 PM
06/22/08 08:22 PM
64 is a little colder plug then the 65. I use 64`s with no problems. Champions worked well for me too. Mike
what does that mean,by a colder plug.. does i have to do with my mods on the engine..
as for the champion plugs, i think im going thata way!they been out there for ever!
[Re: mopars4ever]
#78475
06/22/08 08:24 PM
06/22/08 08:24 PM
thanks i got it, sorry im a little slow on typing , alway one question behind!
[Re: mark7171]
#78476
06/22/08 08:25 PM
06/22/08 08:25 PM
because your car is cooler..
THATS RIGHT!!!! LOL
#78479
06/22/08 10:55 PM
06/22/08 10:55 PM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
A colder plug dissipates heat at a faster rate which makes it run cooler. A hotter plug dissipates heat slower so it runs hotter.
I have had bad luck with champions and will never run them again. Autolite only for me.
