Axle "U" Bolts #784510
08/26/10 09:03 AM
08/26/10 09:03 AM
Central Pa. U.S.A.
Bigfury Offline OP
Bigfury  Offline OP
Central Pa. U.S.A.
Installing a B-body axle into an E-body. Anyhow found chromemoly "U" bolts.Might they possible be reuseable? Just wounding why use a different metal if standard ones work? Thanks in advance,tons of knowledge here.
Re: Axle "U" Bolts [Re: Bigfury] #784511
08/26/10 02:56 PM
08/26/10 02:56 PM
Under My Car
Mopar_Country Offline
Under My Car
The only response I could give you would be that you want to use a grade 8 bolt.
