how much gain/ carb swap #784475
08/26/10 01:21 AM
08/26/10 01:21 AM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
just got to thinking, how much has one picked up from going from a ootb holley dp to a pro tuned carb from one of the carb guys like biggs or pro systems etc?? im really thinking id like to hit the 10 flat mark or better
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: how much gain/ carb swap [Re: Stroker Scamp] #784476
08/26/10 09:03 AM
08/26/10 09:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The only time I used a pro type carb was when I had
my 1050 dom build up for E-85.... I went exactly the
same.... if it is the same flow I realy dont think you
will see a increase but alot of those guys up the flow
rate on them so thats not a true apples to apples...
of course that will depend on if you can tune a carb
in the first place.... and if it was properly tuned
for your set up
Re: how much gain/ carb swap [Re: MR_P_BODY] #784477
08/26/10 10:30 AM
08/26/10 10:30 AM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Not to hi-jack this thread but does putting on billet blocks and baseplates really help?? I have a 850dp with a pro-form body but stock blocks and plate....I was just wondering??
Re: how much gain/ carb swap [Re: MIKES_DUSTER] #784478
08/26/10 11:45 AM
08/26/10 11:45 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The baseplate would only provide a performance increase if (a) it has thinner shafts to improve airflow and / or (b) your standard baseplate is warped and causing sealing issues.
Assuming no leakage issues w/ the your original metering blocks, billet metering blocks would only be an improvement if the emulsion circuits are tuned better for your particular combination. One of the main benefits of most of the billet blocks is that you can make circuitry changes easier than standard cast blocks.
Re: how much gain/ carb swap [Re: Stroker Scamp] #784479
08/26/10 02:22 PM
08/26/10 02:22 PM
I have seen and heard of a lot of high dollar custom carbs not work as well as the same size new Holleys out of the box on engine dynno testing Mike, there are some very good custom carb builders out there but not all of them are
Re: how much gain/ carb swap [Re: Cab_Burge] #784480
08/26/10 04:33 PM
08/26/10 04:33 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
From what I hear they are hit and miss from all the companys, some guys claim "so and so" built my carb and it picked up two tenths and drivability was way better while some other guy lost two tenths from the same builder and drivability now sucks. I have heard so many stories from both sides of the fence I don't know what to beleive. I prefer metering rods any how
I have an 830HP double pumper I am going to try on my 414 stroker but it will probably end up in the parts for sale section. I love the holley look but I can never get one to work great, only so-so at best (I did have one 770 street avenger on a 318 that ran great but sucked gas). I am going to try this one for a while and if it don't work it will get replaced by a T.Q. I know how to make them run great
Re: how much gain/ carb swap [Re: HotRodDave] #784481
08/26/10 11:37 PM
08/26/10 11:37 PM
pacific northwest
pacific northwest
thanks guys, i really didnt think it was worth it. more courious than anything
