Torsion Bar Adjustment? #784087
08/25/10 08:03 PM
08/25/10 08:03 PM
Illinois
Tully Lee Offline OP
Illinois
One other question I have is in regards to Torsion Bars.
I had a Mopar friend of my adjust the Torsion bars about two years ago. The car looked like it was sitting up too high.
He made adjustments and gave the car a real nice looking profile stance.
Now two years latter I just notice that the drivers front and rear is a little higher than the passenger side front an rear. All air pressure in the tires is exact.
So, can the adjustment he made on the torsion bars go bad are adjust them selves after time?
How difficult is it to re-adjust the torsion bars.
And for the dumb question: 1) Where is the torsion bars? 2) Where and how do I make the adjustments.
I could call him up but I want to start to learn some of this stuff on my own.
Tully Lee
Re: Torsion Bar Adjustment? [Re: Tully Lee] #784088
08/25/10 10:02 PM
08/25/10 10:02 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
the torsion bar acts as the spring
the adjustment didnt go bad, most likely the spring has lost some of its strength
they are very easy to adjust
get a 3/4 socket on a 1/2" drive with a 3" extension
the adjuster bolt is located under the lower control arm, facing down towards the street
if you want a side of the car to be higher, just tighten the bolt clockwise + it will raise the height
to lower, loosen the bolt, counter clockwise
Re: Torsion Bar Adjustment? [Re: TONY_DAGOSTINO] #784089
08/25/10 10:05 PM
08/25/10 10:05 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Jack the front of the car up and let the wheels hang before adjusting.
Then lower it and roll it forwards and back each way then recheck.
Re: Torsion Bar Adjustment? [Re: Tully Lee] #784090
08/26/10 02:07 AM
08/26/10 02:07 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
After adjusting the torsion bars, be sure to have the alignment checked...
Just my $0.00...
