67 hemi motor is done, but need new aircleaner base.. #784016
08/25/10 05:17 PM
08/25/10 05:17 PM
mr norms avenue
5571 Offline OP
5571  Offline OP
mr norms avenue
any updates on the metal bases that allow the newer edlebrock carbs to fit under the original 67 style aircleaner (larger diameter carb openings)? I know someone was close to having the expensive base done by now...
hope I can get without buying the lid to match
-bob
67 hemi GTX silver 4spd, 70 cuda convert 340 4spd, 71 cuda 340 4spd (Curious Yellow, white billboards/interior), 70 Mr Norm's Challenger 440 4spd
Re: 67 hemi motor is done, but need new aircleaner base.. [Re: 5571] #784017
08/25/10 07:10 PM
08/25/10 07:10 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
This is why I sell so many clone Hemi carburetors (small tops). I think you are in luck though, I believe Mopar Performance sells a Chrome Dome Base with the larger openings for your carbs.
Re: 67 hemi motor is done, but need new aircleaner base.. [Re: 5571] #784018
10/10/10 10:16 AM
10/10/10 10:16 AM
Mopartom Offline
Mopartom  Offline
I make the chrome dome bases out of steel for the Edelbrock carbs using the standard lid.
Tom 734-775-7799
