Engine won't fire up again....advice? SOLVED!
#783838
08/25/10 01:01 PM
08/25/10 01:01 PM
Posts: 292 State of Flux
Dodge Don
State of Flux
Car was running fine and ran fine loading it onto a trailer. When I went to unload it started right up but died about 3 seconds later (as if a switch had been thrown...no sputtering). Would not fire up again.
Getting fuel and spark at plug wires.
Discovered a blown fuse, replaced and when trying to start the car it blew the fuse again. Noted that the fuse connectors had positive continuity even with fuse removed so pulled each wire and found accessory wire causing continuity. Unhooked it and replaced new fuse.
Car started right up but died about 3 seconds later again and won't fire up again just like before....no blown fuse this time.
The car has MP elect ignition and MSD 6AL box. I'll follow the MSD troubleshooting suggestions but was wondering if anyone had any other experience/suggestions. Not good at electrical stuff...
Thanks.
Re: Engine won't fire up again....advice?
[Re: Sinitro]
#783845
08/25/10 08:51 PM
08/25/10 08:51 PM
Dodge Don
State of Flux
Check the reluctor gap inside the distributor, if too wide the MSD box will not fire the coil..
Just my $0.00..
How do I do that?
[Re: Dodge Don]
#783847
08/26/10 07:15 PM
08/26/10 07:15 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Just my $0.00..
How do I do that?
OK.. Here U go. 1. Pop off the distributor cap 2. Pull cap back so U can look down inside 3. U will see the magnetic pickup and reluctor piece (on center shaft) 4. The reluctor will have raised parts that point outward 5. As the distributor turns the raised part passes by the pickup, this what makes/break the contacts which fires ECU box/coil 6. Rotate the distributor so that raised part is facing the pickup, the clearance gap should be no more than 0.006"-.008" If this is too wide the pickup will NOT switch (make/break)..
The pickup is a simple passive switch and we often find the gap is too wide, very common in cold climates. The gap should be set by a brass feeler guage but if not available a thicker business card can work, just be sure to check the distributor for adequate clearnace by rotating the engine completely.
Just my $0.00...
[Re: Dodge Don]
#783849
08/26/10 09:29 PM
08/26/10 09:29 PM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
I tested the ohms across the two magnetic pick up wires coming from the distributor and got around 60 ohms. Seems awfully low. I tested with the battery unhooked.
You should get between 400 and 600 OHMS on the pickup. Switch to AC voltage and spin the distributor you should get a least 1 volt.
[Re: Dodge Don]
#783851
08/27/10 03:12 PM
08/27/10 03:12 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Don.. how's the bulkhead connector, especially the power source going into the car? How's the backside of the dash look like, i.e the wires going to the amp gauge and/or steering column? Everything out in the engine compartment may check out fine.........
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: '84 D150 Shorty]
#783857
08/27/10 08:43 PM
08/27/10 08:43 PM
Mopar_Country
Under My Car
Then it has to be the magnetic pickup in the dizzy, either out of adjustment or the the pickup itself somehow got toasted when you had yer short....
As was stated earlier in the thread he is only getting 60 ohms at the pickup. That is way low. Should be 400-600, and with the meter switched to volts one should get at least 1 volt AC when spinning the dizzy.
