Re: DoctorDiff's rear disc kit
[Re: AndyF]
#783684
08/25/10 09:53 AM
08/25/10 09:53 AM
Posts: 1,263 Southwestern Ontario Canada
racealittle
I shot a couple of pictures while I had the car up on jacks the other day. This is a really nice disc brake setup that Cass had engineered for the Mopar rear ends. This setup keeps the tapered roller bearings rather than forcing you to switch to the green bearings. It also uses an OEM quality caliper with weather seals and e-brake. Nice setup that is fairly compact and lighweight.
I studied the Fine Lines kit a friend bought that requires the green bearings. I don't see why they say green bearings are required. The Fine Lines kit won't work with factory rally rims, I hear that the kit Cass offers will.
The Dr. Diff kit looks very nice in comparison, which may justify the price difference for some.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: MR_P_BODY]
#783687
08/25/10 11:52 AM
08/25/10 11:52 AM
Posts: 31,066 Oregon
AndyF
Andy what is that arm on the turnbuckle ... I dont know what I'm seeing
Adjustable rear anti-sway bar. This is a road race car, not a drag racer.
DoctorDiff's rear disc kit now has been approved at 150 mph!
[Re: MIKES_DUSTER]
#783691
08/27/10 02:30 PM
08/27/10 02:30 PM
Posts: 2,955 GA
roadrunninMark
GA
Another for the doc diff rear kit. I had some questions as well and he was always happy to answer them. Here is a shot of mine installed: Mark
[Re: DoctorDiff]
#783693
08/27/10 07:11 PM
08/27/10 07:11 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I love my Dr Diff disc brakes! The combination of parts he recommended on my '68 A-body give nearly perfect balance and modulation. They have saved my bacon a few times in critical finess braking situations. The price is right too!
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: DoctorDiff]
#783694
08/27/10 08:43 PM
08/27/10 08:43 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
These look great. Can I ask a dumb question??? Well I'm gonna...... If you don't have green bearings and they are required for a brake setup, what can happen? What do you gain? Lose? Thanks in advance
[Re: AndyF]
#783697
08/31/10 11:38 AM
08/31/10 11:38 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
So this pic is ov a road race car? What size are those rotors in the picture?
Can i assume that the 11.7" rears will fit under stock 15" steel rims? 15x8" Ramcharger rims? How would a 3200lb E-body brake with 11.75/11.7" discs all 'round...???
I've been thinking about this idea for a long time for my 70 Challenger. Last time i checked (long ago) i thought it was AndyF making conversion brakes for Mopars, but now i see his car with Dr. Diff's brakes... Hmmm...
Would the 11.7" rear set-up be lighter than a drum brake set-up?
