carb flooding problem #783507
08/24/10 10:33 PM
08/24/10 10:33 PM
abc440 Offline OP
abc440  Offline OP
I have a eldebrock 750 (ele choke) on 440. It tends to flood real easy if it does not fire on the first crank over. The carb set up is the same as the 750 manual choke. Idle screws are one and one half turns out. Can idle screws affect flooding? THANKS DAVE
Re: carb flooding problem [Re: abc440] #783508
08/24/10 10:40 PM
08/24/10 10:40 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
2 main reasons a carb floods are
1 fuel pressure to high
2 floats are set to high.
I am truckless..
Re: carb flooding problem [Re: 340SHORTY] #783509
08/24/10 11:22 PM
08/24/10 11:22 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
You need to check to make sure the choke butterfly is not being pulled down when cranking. They should never be completely closed, and when the car starts should open up slightly. Its real easy to set an electric choke up to rich at start, try leaning it up by turning the choke adjustment a little CCW. Of course if this thing is burning real rich when running see above
Re: carb flooding problem [Re: abc440] #783510
08/24/10 11:31 PM
08/24/10 11:31 PM
No. Might need less AP squirts when starting. On my 1406 eddy the choke pullof (an internal vacuum piston inside the round black elec choke cover does not open the choke when it starts and the elec choke comes off WAY too fast. I'm OK now but I need to get on it before fall.
