B Body exhaust system swap #783294
08/24/10 04:53 PM
08/24/10 04:53 PM
moparkc Offline OP
moparkc  Offline OP
Looking at purchasing a TTi used exhast system (collectors back)off of a 67 Coronet to put in my 70 Roadrunner.
Will the 67 B body exhaust from TTi swap over to a 70 B body??
Re: B Body exhaust system swap [Re: moparkc] #783295
08/24/10 05:27 PM
08/24/10 05:27 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm not sure. The gas tanks are completely different. Call TTi and see. to the mufflers should be the same.
Coming soon!!!!
Re: B Body exhaust system swap [Re: Mr.Yuck] #783296
08/24/10 05:56 PM
08/24/10 05:56 PM
moparkc Offline OP
moparkc  Offline OP
Good suggestion, called TTi and the tail pipes are different. Anybody have a a big preference comparing Pypes Stainless Steel exhaust to Summit's Aluminized steel exhaust? Little over $200 differnce between the two. Will I be better off spending the extra?
Re: B Body exhaust system swap [Re: moparkc] #783297
08/24/10 08:51 PM
08/24/10 08:51 PM
Arizona
az426john Offline
az426john  Offline
Arizona
I think it depends where you live.
If you live anywhere other than the dry southwest or Washington desert I would spring for the Stainless.
Just my opinion.
