Re: Surface rust and paint removal.
[Re: batt2rm]
#78257
06/22/08 10:13 AM
06/22/08 10:13 AM
Posts: 708 Mechanic Falls, Maine
4BBodies
mopar addict
mopar addict
I have had similar conditions, I use 80 grit DA paper on surface rust. I DA it down until all traces of rust are gone, (it will be stubborn!) don't grind it off, it will wharp. Take it slow, move around, keep the heat down. Then use a good metal etch on it, and let it dry a day or two. I then use 180 grit DA, and prime. Whatever etch that is left is in the pits, (you will see dark converted spots) and most primers are compatible with them, and stick just fine. It is slow going, but you can do the area the size of a hood in about an hour. I did one this way, and left it outside again, it has not rusted yet.
[Re: batt2rm]
#78259
06/22/08 11:31 AM
06/22/08 11:31 AM
Challenger 1
Cincinnati, Ohio
Good info thanks, I am still curious to see if there is a liquid or jell out there that removes rust.
There is... but I would use sand paper. 80 grit is what I would start with. Good luck and have fun.
[Re: batt2rm]
#78262
06/24/08 01:34 PM
06/24/08 01:34 PM
Posts: 529 Marilla, New York
RalleyA12
Marilla, New York
Ebay item 170150199830 evaporust. I bought 5 gallons, offered him $60 and he took it.
[Re: 68SportSatvert]
#78266
06/26/08 12:27 AM
06/26/08 12:27 AM
DaytonaTurbo
Manitoba, Canada
I recently used a product by KBS called Rust Blast. You spray it on and keep the area wet for a period of time then wash it off. I used a power washer and it worked GREAT! It leaves a galvanized finish and etches the metal. You can prime over it once it air dries. Send me a PM with a good email and I'll send you some pics of what it looks like and how well it worked for me.
Almost sounds too good to be true. Post a couple pics for us to see!
