64 Crew, The Vietnam Bomb #782404
08/24/10 01:27 AM
08/24/10 01:27 AM
Central Utah
Mopargnome Offline OP
Central Utah
I am doing a build thread on a Sweptline site but thought I would share it here too. I bought this truck in August of 1999 and immediatley shaved the door handles and replaced one rocker. I drove it for a while then parked it. It sat for years while I collected parts. I got it to the house last year and blew the thing apart and put a 78 D-200 frame clip on it.
Re: 64 Crew, The Vietnam Bomb [Re: Mopargnome] #782405
08/24/10 01:30 AM
08/24/10 01:30 AM
Central Utah
Central Utah
While I had the cab off the frame I did the suicide rear doors.
Re: 64 Crew, The Vietnam Bomb [Re: Mopargnome] #782406
08/24/10 01:31 AM
08/24/10 01:31 AM
Central Utah
Central Utah
The other side
Re: 64 Crew, The Vietnam Bomb [Re: Mopargnome] #782407
08/24/10 01:33 AM
08/24/10 01:33 AM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
Cool ... you making it a duallie ?
Re: 64 Crew, The Vietnam Bomb [Re: Mopargnome] #782408
08/24/10 01:34 AM
08/24/10 01:34 AM
Central Utah
Central Utah
Then I threw it back together to put it away because I was getting some new work and needed the shop space that the truck was taking up. Then it sat until a couple weeks ago. I spent that time collecting more parts for it.
Re: 64 Crew, The Vietnam Bomb [Re: Mopargnome] #782409
08/24/10 01:38 AM
08/24/10 01:38 AM
Central Utah
Central Utah
I wound up picking up a complete early 91 diesel, 5 speed truck. Donor! Thanks RodStRace!
Re: 64 Crew, The Vietnam Bomb [Re: Mopargnome] #782410
08/24/10 01:40 AM
08/24/10 01:40 AM
Central Utah
Central Utah
With the help of a couple friends and a plasma cutter the Cummins and trans were set in the truck. Progress again!
Re: 64 Crew, The Vietnam Bomb [Re: Mopargnome] #782411
08/24/10 01:41 AM
08/24/10 01:41 AM
Central Utah
Central Utah
Here is what it looks like from the inside.
Re: 64 Crew, The Vietnam Bomb [Re: Mopargnome] #782412
08/24/10 01:44 AM
08/24/10 01:44 AM
Central Utah
Central Utah
I did some trading for an 05 3/4 ton rear axle. More details on this later.
Re: 64 Crew, The Vietnam Bomb [Re: Mopargnome] #782413
08/24/10 01:46 AM
08/24/10 01:46 AM
Central Utah
Central Utah
I have spent alot of time welding up all the interior seams. Now I got alot of grinding left to do.
Re: 64 Crew, The Vietnam Bomb [Re: Mopargnome] #782414
08/24/10 01:48 AM
08/24/10 01:48 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
you are welcome! I'd recognise the back of that hand anywhere!
Re: 64 Crew, The Vietnam Bomb [Re: Mopargnome] #782415
08/24/10 01:51 AM
08/24/10 01:51 AM
Central Utah
Central Utah
Then last week I got all the stock intercooler stuff off of a 92 to add it to my setup. This is where the fun starts. The engine bays in these old swepty trucks are not long enough for all this. Yea I could just shove the motor way back but then I'd have to get creative with the shifter and making new motor mounts. I have a different idea on how to approach this.
Re: 64 Crew, The Vietnam Bomb [Re: Mopargnome] #782416
08/24/10 02:07 AM
08/24/10 02:07 AM
Central Utah
Central Utah
I trimmed the stock radiator brackets off the core support then fitted it up to see where everything is at. The support now sits 1 3/4 inches foward of the original location. I need another 1/4 inch to get good clearance between the fan and radiator. I do not have a condenser yet, eventually it will get a vintage air or similar setup. How thick is a condenser? Should I go foward another inch and hope for the best or give myself 2 to 3 inches?
Re: 64 Crew, The Vietnam Bomb [Re: BeEtLeJuIcE !] #782417
08/24/10 02:10 AM
08/24/10 02:10 AM
Central Utah
Central Utah
No on the dually. I had thought about it but the rear axle didnt cost any money out of my pocket so that what I am using.
Re: 64 Crew, The Vietnam Bomb [Re: Mopargnome] #782418
08/28/10 12:01 AM
08/28/10 12:01 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
What, no updates? Don't tell me it's going to sit for another year before the next post!
Re: 64 Crew, The Vietnam Bomb [Re: RodStRace] #782419
08/31/10 12:01 AM
08/31/10 12:01 AM
Wisconsin
N
NI4NI Offline
NI4NI  Offline
N
Wisconsin
Dave,
You've initiated a very interesting project that some of us would like to keep a pulse on. That's a 5.9 liter Cummins ..... correct? If my front end would have held the mass of such, that'd been the engine and drive train of choice. Please take the time to periodically photograph the project and post on this site because many of us could greatly learn form what you're undertaking.
Keep up the momentum,
Brian
1974 Plymouth Satellite Sebring Plus, 4bt turbo intercooled Cummins, SlapStik A727, 224 rear end gears http://www.4btswaps.com/forum/showthread.php?t=9632
Re: 64 Crew, The Vietnam Bomb [Re: NI4NI] #782420
09/01/10 09:38 PM
09/01/10 09:38 PM
Central Utah
Central Utah
I got the old rusty floors out of it last weekend. I also got the trans crossmember up where it needs to be. Now the motor sits real close to where it needs to be. I have been debating on how to make the intercooler stuff all fit and I think I got it figured out. Thanks Brian! Post a couple pics of your car since I couldnt see them in the link. Sounds different and very cool.
Re: 64 Crew, The Vietnam Bomb [Re: Mopargnome] #782421
09/02/10 08:47 AM
09/02/10 08:47 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
How much work was it to put the cab and front clip on the newer frame?
Re: 64 Crew, The Vietnam Bomb [Re: 446acuda] #782422
09/02/10 10:51 AM
09/02/10 10:51 AM
Central Utah
Central Utah
I did a frame splice. You can see in the last pic where the two are put together. And doing that only took a weekend.
Re: 64 Crew, The Vietnam Bomb [Re: Mopargnome] #782423
09/02/10 11:44 PM
09/02/10 11:44 PM
Wisconsin
N
NI4NI Offline
NI4NI  Offline
N
Wisconsin
Howdy Dave,
You know, your project looks to be about 4X the work that my measly swap was, and my hope is that you hang in there through the thick and thin of it. There were numerous times that some swear-laced prayers were muttered just to coax me past the latest engineering-based hurdle that I was being faced with.
If you want to see my Cummins-powered beast, I think she can be found on this forum at
https://board.moparts.org/ubbthreads/show...e=4#Post5955589
Keep fabricating and wrenching,
Brian
