Re: World Aluminum Block Main Studs CAUTION
[Re: moparniac]
#782324
09/30/10 07:32 PM
09/30/10 07:32 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I have been using these for months and months...they are the correct numbers.
RIP Monte Smith
[Re: rowin4]
#782327
10/18/10 07:16 PM
10/18/10 07:16 PM
Posts: 6,295 U.S.
moparniac
U.S.
Bump!!! Any metal reports yet??? Speed shop called and my studs showed up!!!! Anyone need any Chinese Ones?
Mopar Performance
[Re: CompWedgeEngines]
#782330
10/19/10 12:38 PM
10/19/10 12:38 PM
Posts: 901 oh
julian2007
oh
So with the arp studs what is the correct torque speck and what is the correct lube? Thanks,Bruce
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
[Re: Keith Black®]
#782331
10/19/10 12:55 PM
10/19/10 12:55 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
I'm in Australia and I have one of those blocks. Will get the replacement studs in any event, and most definitely agree with your comments. At least some of us found out before the block has gone into use (phew). It does raise SERIOUS concerns about the integrity of the block overall. Any feedback on this would good... I see someone windowed a World block not long ago on this site .... I have one that was the most consistant and trouble free 572 B1 motor I have built to date. I had my machinest check the studs and they were ARP, so we put it together and I'll be using it next year. It makes 1000+ so, I wouldn't be afraid of them. And I think the other guy that windowed one was 66CHARGER, or something in Oregon. That had nothing to do with the block.
[Re: sg66mopar]
#782334
11/24/10 11:02 PM
11/24/10 11:02 PM
Posts: 6,295 U.S.
moparniac
U.S.
this is what I got from another member posted
OK, I have done some research on these main studs.If you already have the ARP cross bolts and ARP nuts on the "no name" studs, you can replace the main studs with ARP #AR4.620-1LB X 8 and #AR4.400-1LB X 2. I did a google search and vendors have them for aprox. $5.50 each.
Mopar Performance
[Re: sg66mopar]
#782335
11/25/10 01:55 AM
11/25/10 01:55 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Well, I finally got a new block to replace the one I sawed in half. Now I need the ARP stud kit. Summit and Jegs (UGH) are out almost two weeks. Anybody know where to get them faster. Just for reference the part number is 145-5603.
BTW, not interested in flak from the World Products haters. It's what I'm usin' and that's that!
Also BTW, I've got a good used, low mile World Aluminum block for sale. It's already been pre-lightened and has some good ventilation on each side so it shouldn't overheat.
Sounds like the item your trying to sell just don't hold water. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: sg66mopar]
#782336
11/25/10 12:03 PM
11/25/10 12:03 PM
CompWedgeEngines
Syracuse,NY
I believe I have the stud kits and individual studs at the shop. I wont be there today, ( hopefully!), but I can check tommorrow. Drop me a PM or vica versa.
RIP Monte Smith
[Re: rowin4]
#782339
01/21/11 02:02 PM
01/21/11 02:02 PM
Posts: 6,295 U.S.
moparniac
U.S.
The part numbers are posted above for the stud replacements! I got them and they are right !!! I threw the other ones away !
Mopar Performance
[Re: rowin4]
#782340
01/21/11 07:51 PM
01/21/11 07:51 PM
Posts: 2,175 Duloc
The Shadow
Duloc
Where did you get that information? ![](/ubbthreads/images/graemlins/popcrn.gif)
I saw the new blocks at FHO Mopar p/n and name machined off the blocks New studs Added 1/8 npt plugs in the lifter valley on each side of the oil holes. Just a few things I ![](/ubbthreads/images/graemlins/scope.gif)
[Re: moparniac]
#782341
05/15/11 01:52 AM
05/15/11 01:52 AM
Posts: 6,295 U.S.
moparniac
U.S.
Gentlemen,
I'd like to introduce myself. My name is Paul Kaufman. I have worked for World Products as a technical representative and engine builder for approximately a decade. I have been building engines professionally for the better part of my life with over 40 years experience in both the private industrial sector and performance speed industry. I have been asked to express my opinion ( and that of World Products ) regarding concerns some of you may have with the main studs utilized on the Mopar iron and aluminum Hemi and Wedge blocks manufactured by World Products. World has manufactured several thousand of both the iron and aluminum blocks in the last few years and recently we have heard that some of these studs have failed when torqued. I have personally assembled many of the Hemi and Wedge engines at World Products, and have not had any issues. I would love to be able to say that there are many torque wrenches that are being used that were manufactured in third world countries and that is the problem, but that would be unfair. World Products does not manufacture studs nor do we import inexpensive hardware from China. The studs used on the Mopar iron blocks are to Mopar's engineering specs and our engineers determined those studs to be of sufficient quality for use on World Products aluminum blocks as well. These studs are not ARP. More recently World Products chose to switch to the ARP brand studs, not because we found them to necessarily be better, but to align ourselves with the hardware being utilized on our Chevy and Ford blocks. I would like to point out that over the years I have experienced failure with hardware manufactured by ARP, but grab another one and move on. I have also experienced a rod breaking or a lifter failing, all from big name brand manufacturers, but that doesn't mean the sets of parts were all defective. The point is sometimes rods break, lifters fail and bolts and studs stretch, break, threads gall, etc. It is the nature of metal objects that have been cast, poured, machined and manipulated that a small percentage will fail, regardless of who manufactured the item. If you find one defective stud that does not mean all the studs are bad. As with most manufacturers, World Products has a warranty policy. Should you find any defect in any of World Products parts or components within one year of purchase simply contact us and we will be more than happy to exchange that defective part. If you would like to change out your hardware to a complete set of ARP studs, you can purchase them from your local ARP dealer or retailer. The caps are located by ring dowels and block registers. The line bore will not be affected. The torque rating on the ARP studs remains the same. Thanks for your time, Paul
so your saying to go pound sand pretty much!
sounds like it! ![](/ubbthreads/images/graemlins/Twocents.gif)
Mopar Performance
