Page 6 of 11 1 2 4 5 6 7 8 10 11
Re: World Aluminum Block Main Studs CAUTION [Re: moparniac] #782224
08/27/10 10:37 PM
08/27/10 10:37 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well not much of a dog in this hunt, I have built three of the World block engines however. So here are a few things to ponder. First off it says nowhere that they use ARP studs correct? So I do not see any issue there. The blocks I have done were all fine, had no issues with stud torque and do not recall any issues with them. However, why ARP nuts but not studs? Seems almost borderline shady, I imagine most folks see the ARP nut and ASSUME the stud is as well. Well you know what they say about assuming anything. I also own a shop and go above and beyond on almost a daily basis to make customers happy. But that is my choice. Seems World does state they will replace any fastener found to be defective within its warranty guidelines. Sounds like the automotive aftermarket manufacturer thing to say, most woudl reply the saem way.
I think World is kinda getting thrown under the bus here. Not totally undeserving however. Seems maybe there was a slight deception going on with the nut/stud deal. But knowledgeable guys know about that issue. Blaming any failure on the end user is well kind of gutless IMO. FWIW I had an issue with a World block. It was a BBC Merlin block. Had the oil gallies drilled into the water jackets. They took care of it and sent out a fresh new block to replace it and told me to keep the bad one. It was subsequently fixed and it still in use now.
SG why is the KB not an option for you? I run one and it works great...
Re: World Aluminum Block Main Studs CAUTION [Re: RylisPro] #782225
08/27/10 10:40 PM
08/27/10 10:40 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Indy may not be Keith Black but at least their studs are ARP
The cross bolts are marked "DB". Would they matter as much?
Why do the studs only go halfway through the nuts? If that cap is all the way down (which it appears to be) those studs are at least 3-4 threads too short, no matter whose name is on them.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: World Aluminum Block Main Studs CAUTION [Re: Evil Spirit] #782226
08/27/10 10:44 PM
08/27/10 10:44 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
The motor is not assembled yet and nuts have no torque on them
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: World Aluminum Block Main Studs CAUTION [Re: Evil Spirit] #782227
08/27/10 10:49 PM
08/27/10 10:49 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Although I doubt that World will miss the business, it is looking like their response may cost them more that the cost of a few sets of main studs.
Maybe it will mean a little more business for KB.
Master, again and still
Re: World Aluminum Block Main Studs CAUTION [Re: CompWedgeEngines] #782228
08/27/10 10:53 PM
08/27/10 10:53 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Where is the "foot in mouth" smiles at?? LOL
Of coarse it was the torque wrench, what was we thinking..
So those bolts were just as good as ARP bolts? Even though World has decided to replace them now with all ARP fasteners just like Ford and Chevy? Why order or deal with them in the first place if you have a contract with ARP for your main supplier?
Bottom line
Money
Money
Money
Money
First let me say that My bolts had NO torque problems, there where cycled at least 3 times minimal. Once when from the factory, I actually checked them when I broke them loose with my torque wrench. Then I slapped in some bearings and measured ID for bearing clearance with the dial bore gauge. Then again during final assembly.
My torque wrench is made by Proto..Its probably 15-20 years old....I check it 2-3 times a year for accuracy. The Snap-On man has a checking tool mounted in his truck..Just takes a few seconds to verify readings...
Let me say its pretty lame to start crying about inferior "China" made torque wrenches, that by chance some might use...
Im just saying this web site reaches people on a global level, and news about bad company ethics and poor parts will spread faster than a snotty nose at the local day care.
Especially In the days of this economy when there is several diff choice of the same part...for the same money..
Re: World Aluminum Block Main Studs CAUTION [Re: Bob_Coomer] #782229
08/27/10 10:59 PM
08/27/10 10:59 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
To clarify, I use Snap On torque wrenches, and actually do calibrate them. Calibration sticker is on them all.I had access to a precision tool and die shop where my brother worked, and he would also certify my mics.Far from Chinese quality.
I also have a KD dial type torque wrench, and it is very accurate.
RIP Monte Smith
Re: World Aluminum Block Main Studs CAUTION [Re: RylisPro] #782230
08/27/10 11:24 PM
08/27/10 11:24 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Reading through there catalog again and found a interesting paragraph on there chevy short block assembly. "Also available are premium quality ARP fasteners, as used in complete World engines" So I guess the spec. sheet I got with my block was correct it states main studs 1/2"-13. And if I would have bought a complete engine it would have had ARP studs,maybe.
I should have read the chevy spec. sheet and read between the lines also. I'm just changing mine out before machine work just as Paul would say to sleep better at night. $ 125. bucks down but thats just a drop in the bucket for this build.
Re: World Aluminum Block Main Studs CAUTION [Re: CompWedgeEngines] #782231
08/27/10 11:28 PM
08/27/10 11:28 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I don't think it's "wrong" that they don't use ARP stubs....but using ARP nuts on them to fool people is just wrong.
Re: World Aluminum Block Main Studs CAUTION [Re: DarkSideofNY] #782232
08/27/10 11:40 PM
08/27/10 11:40 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Hi guys, Im Chuck and I will represent WORLD Products. The ARP stud kit is $112.99 at Summit.
Im also the new MOPAR guy here and am currently building an all aluminum 540cu World HEMI.
So I feel your pain with the studs, I even checked
mine, and they are ARP. Any questions you guys have fire away and I will find you an answer.
The boss over here at World is now aware of the problem and has issued a statement to our foundry where both the iron and aluminum are cast. All if any left non ARP hardware is being discarded.
ONLY ARP hardware will be used and to our knowledge that is what was sold. We are currently going through the HEMI and WEDGE inventory here at WORLD to make sure this does not happen again.
CHUCK
Does any one have the part number for the ARP main stud kit for the world block? I have a new set of ARP studs for an OEM 440 block that I was going to use, but the junk studs out of the world block are longer, so I don’t think the ARP studs I have will work. The shop that is machining my world block told me today that the world studs torque to 100 foot pounds and felt solid. The line bore was dead on. He said they think the studs will be okay. He did say there were other problems with the block. The lifter bores and oil pump shaft busing were both under size and had to be honed. No big deal there. I’m not going to gamble on the world studs. I called Summit and they don’t have a listing for the ARP kit that ol chucky boy at world claims they have for $112.99. Hay chuck, how about giving us a part number? Better yet why doesn’t world man up and stand behind their product and replace the junk studs they installed with ARP studs?
Re: World Aluminum Block Main Studs CAUTION [Re: Dabee] #782233
08/27/10 11:49 PM
08/27/10 11:49 PM
rowin4 Offline
rowin4  Offline
The Part # for the ARP World block main studs is 145-5603
Re: World Aluminum Block Main Studs CAUTION [Re: RylisPro] #782234
08/27/10 11:53 PM
08/27/10 11:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
One thing I dont like is that the stud ISNT long
enough in the pics.... sure doesnt look like the
stud diameter sticking into the nut... thats a minimum
Re: World Aluminum Block Main Studs CAUTION [Re: rowin4] #782235
08/27/10 11:57 PM
08/27/10 11:57 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Thanks, I just ordered a set from Summit!
Re: World Aluminum Block Main Studs CAUTION [Re: rowin4] #782236
08/27/10 11:59 PM
08/27/10 11:59 PM
rowin4 Offline
rowin4  Offline
Got a e-mail back from Paul on the main cap side bolts . Seems there not all ARP, 12 point head are , 6 point are as he say's generic.
40-45 ft.lbs for the 12 point with oil , DO NOT TORQUE THE 6 POINT BEYOND 35ft.lbs with oil
Re: World Aluminum Block Main Studs CAUTION [Re: MR_P_BODY] #782237
08/28/10 12:01 AM
08/28/10 12:01 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
One thing I dont like is that the stud ISNT long enough in the pics....
fixed
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: World Aluminum Block Main Studs CAUTION [Re: RylisPro] #782238
08/28/10 12:05 AM
08/28/10 12:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
fixed
Much better... I assume you just backed the stud out
of the block some
Re: World Aluminum Block Main Studs CAUTION [Re: MR_P_BODY] #782239
08/28/10 12:11 AM
08/28/10 12:11 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I assume you just backed the stud out of the block some
The block has no crank so the nuts have NO torque I just hand tightened the nut and took a photo...
ah whatever... I give up...
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: World Aluminum Block Main Studs CAUTION [Re: RylisPro] #782240
08/28/10 12:25 AM
08/28/10 12:25 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Ariel I get it if it helps...When you gonna have that thing done?
Re: World Aluminum Block Main Studs CAUTION [Re: Al_Alguire] #782241
08/28/10 12:31 AM
08/28/10 12:31 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Haha! When I earn the money!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: World Aluminum Block Main Studs CAUTION [Re: RylisPro] #782242
08/28/10 12:49 AM
08/28/10 12:49 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
Great post. I had an order in for 5 blocks from a dealer. Cancelled and will now be calling Keith Black. This SUCKS World!!!
Re: World Aluminum Block Main Studs CAUTION [Re: CompWedgeEngines] #782243
08/28/10 01:43 AM
08/28/10 01:43 AM
Delray beach, Florida
P
Performance Only Offline
P
These studs are not ARP. More recently World Products chose to switch to the ARP brand studs, not because we found them to necessarily be better, but to align ourselves with the hardware being utilized on our Chevy and Ford blocks.
statements like the one above remind me of campaign promises and legalese doublespeak. utter nonsense comes to mind. i'd like to be more positive, but having witnessed the stud problem firsthand, all i can say is that it's a real problem.
World was already "aligned" with ARP but obviously chose initially not to use the ARP product for some reason. one can only guess the reasoning behind that move and the more recent shift towards ARP.
i wonder how long it'll take for warranty replacement of the defective studs?
I'm happy World (or anyone for that matter) is making Mopar engine blocks, but i've been on the recieving end of thier customer support more than once, and it ranked right up there with lackluster. best of luck to those affected.
machine shop owner and engine builder
