pesky dipstick tube installation: finally, got it !!
#78213
06/22/08 09:15 AM
06/22/08 09:15 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang.. OK, I have my hemi and I'm installing the dipstick.. Any hints on how to coach it all the way in? I'll get about 3/4's of the way in and just won't go in any further.. It's obviously a reproduction cause I couldn't find an NOS version....
Here's what I'm working with..
Thanks..
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: pesky dipstick tube installation
[Re: HPMike]
#78216
06/22/08 10:30 AM
06/22/08 10:30 AM
hemi68charger
Houston, Tx
If you try to hammer it in you will most likely just destroy it. Most of the repop tubes are made wrong and will not fit in this way.
Here is how you should do it.
- Grind the end of the tube(that goes into the block) so that it can be pressed in with light force. - Fit the tube to the block and run it along the front(#1 manifold tube). Get the clamp that mounts it to the head and mark it's position. - Tack weld the clamp to the tube. - Put a dab of high quality RTV on the end that goes into the block, and stab it in. Clamp it to the Head/manifold.
Works every time, the tube cannot work it's way out, and the nice thing about this is that you can remove and re-install the tube later without destroying it.
That's what I sort of did.. I took a 3/8 wrench which has a gap that will fit around the tube, yet catches the lip down at the bottom. I worked the tube in as far as it would go by hand twisting it back and forth.. Then a tabbed the wrench, which was around the end of the tube resting on the lip, lightly.. Prior to that, I placed some sealant around the tube to make sure there was sealant between it and block. The tube has a OEM clamp on the first exhaust manifold bolt along with the heat wrap... If I can't get the tube all the way in, I'll trim the top of the tube the same width as that of the space the tube didn't go into the block orifice. That way my oil indicator stick will read properly... Otherwise, it's not going to be in the pan the proper depth....
Does this make sense?
[Re: hemi68charger]
#78218
06/22/08 10:47 AM
06/22/08 10:47 AM
Posts: 75,084 U.S.S.A.
JohnRR
U.S.S.A.
Again, this is what I'm working with.... That's how far I've gotten it down, about 3/4 of the total length to go in.
you have another potential issue , is it me or are the studs on your engine mount not sticking out the end of the nuts ? they really should be .
[Re: JohnRR]
#78220
06/22/08 12:30 PM
06/22/08 12:30 PM
hemi68charger
Houston, Tx
Good eye.. I was just tinkering around with the brackets and such.. Made my own until I get my kit Bill over at A+MHightechauto...
I'll eventually put another coat of color on the complete motor once everything's done...
[Re: wings471]
#78221
06/22/08 12:32 PM
06/22/08 12:32 PM
hemi68charger
Houston, Tx
I've run into that problem myself. I used emery cloth on the part that fits into the block. RTV is a good idea but use it sparingly. If you use the 3/8 open end wrench to tap it into the block, make sure you are tapping not hammering, you will damage the tube wihout much effort. It takes patience and more than a few tries using emery cloth.
I'm glad you verified my next step... That's what I was going to do next... Glad to hear you had success with it.......
[Re: hemi68charger]
#78223
06/22/08 08:51 PM
06/22/08 08:51 PM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
I ran in to this on my 440.
The end of the reproduction tube was not perfectly round and was getting an indent on the side of the tube from the block. I filed the sides of the tube...a lot! Working the tube to literally make it a tad smaller and more round. Then gently tapped it in from the top. Worked, no leaks.
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
[Re: hemi68charger]
#78224
06/22/08 09:49 PM
06/22/08 09:49 PM
the freezer trick works, (metal shrinks as the temperature goes down)
[Re: sthemi]
#78227
06/23/08 07:52 AM
06/23/08 07:52 AM
hemi68charger
Houston, Tx
After I broke the first $50 tube I made a tool to install it. If you dont have it in yet I will post a pic of it. It works like a charm...
Thanks ya'll.. Yeaper sthemi, what's the tool? I've cracked the dang thing while "coaching" it in..
Thanks..............
[Re: hemi68charger]
#78228
07/11/08 08:19 AM
07/11/08 08:19 AM
hemi68charger
Houston, Tx
Well, after breaking the previous one and Bill over at A+M Hightechauto sending me another one, I got her installed yesterday afternoon.... With some grinding of the OD of the insertion part of the tube, I got it installed... Now it's time to further my painting detail work.........
Thanks Bill........... By the way Bill, your parts are making the hemi come together rather nicely
[Re: mopar jason]
#78229
07/11/08 10:10 AM
07/11/08 10:10 AM
Posts: 230 Long Island, New York
Tony H
I just put my dipstick in my 383. I am a young guy 31 years old and had an old timer mopar guy tell me to put in the freezer over night. Worked like a charm. I didn't think it would work but give it a try you might be as suprised as I was.
I do this for Ball joints and bushings.. Yes, a few thousands of an inch of contraction goes a long way.
'75 CJ5 with all glass body and a 350 Chevy SB '85 Chevy Stepside (the wife's) '89 Volvo All 100% maintained by me. '70 valiant DD for my son '74 Dart Swinger..Latest endeavor http://home.lyse.net/brox/TonyPage4.html
[Re: Tony H]
#78230
07/11/08 11:01 AM
07/11/08 11:01 AM
hemi68charger
Houston, Tx
Dang,, I forgot about that suggestion... When I read it the first time, I thought that's a nice idea to try....... Oh well.. It's in........
[Re: GreenBlurr]
#78232
07/11/08 07:08 PM
07/11/08 07:08 PM
hemi68charger
Houston, Tx
Lol, you guys always do everything the hard way (except that freezer method sounds nice). The proper tool to use is a sturdy phillips head screw driver (one that fits inside the tube naturally). Drop the screwdriver into the tube so the screwdrivers handle co0mes to land on the rim of the tube, and tap tap tap away with a dead blow hammer. the tube goes right in, and nothing is damaged whatsoever, since the screwdrive is softer than the tube no matter what.
That would be great if it was a straight shot and the force direction was towards the hole in the block..... The hemi tube has too much of a curve..
