Re: World Aluminum Block Main Studs CAUTION
[Re: Bob_Coomer]
#782185
08/27/10 12:00 AM
08/27/10 12:00 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
After looking at Coomers pics, ( which kind of look like ARP "finish")it occurred to me that maybe there are 3 versions of this stud. Here is why I make that statement. There is the definate crap stud, as pictured. Then Bobs, which "look" different, but at least more like an ARP. Then there is the stud that I pictured which is definately the newest ARP. When I first found this problem, I simply got individual ARP studs and made up my own "kits" that I needed. In the meantime, ARP came out with a kit, which is what I showed in the picture. I happened to make a call to a buddy of mine who does a very significant amount of World Hemi blocks, and he too had found that there were problems torquing the studs. Now , with all that being said, it is very very possible that a less experienced assembler or builder could have torqued these and never picked up on it. Its one of those " feel" things you get after doing literally dozens and dozens of engines. You may have gotten away with torquing them once or twice, but if your like I am and mock the motor up a few times for fitment, then these things may have even failed over that short of time.
Also be aware, that if if you change out the side bolts for studs, you will have interference with the oil pump ( or could) that will require some attention. Wirh studs, the heads of the nuts will not clear the backside of the oil pump.
I dont know the answer, but I do know the fix. Hopefully Chuck can step back in and explain. Whatever the case, there definately WAS a problem, but was it every block sold? Who knows.
RIP Monte Smith
[Re: DarkSideofNY]
#782189
08/27/10 06:05 PM
08/27/10 06:05 PM
Posts: 2 NY
DarkSideofNY
NY
Gentlemen,
I'd like to introduce myself. My name is Paul Kaufman. I have worked for World Products as a technical representative and engine builder for approximately a decade. I have been building engines professionally for the better part of my life with over 40 years experience in both the private industrial sector and performance speed industry. I have been asked to express my opinion ( and that of World Products ) regarding concerns some of you may have with the main studs utilized on the Mopar iron and aluminum Hemi and Wedge blocks manufactured by World Products. World has manufactured several thousand of both the iron and aluminum blocks in the last few years and recently we have heard that some of these studs have failed when torqued. I have personally assembled many of the Hemi and Wedge engines at World Products, and have not had any issues. I would love to be able to say that there are many torque wrenches that are being used that were manufactured in third world countries and that is the problem, but that would be unfair. World Products does not manufacture studs nor do we import inexpensive hardware from China. The studs used on the Mopar iron blocks are to Mopar's engineering specs and our engineers determined those studs to be of sufficient quality for use on World Products aluminum blocks as well. These studs are not ARP. More recently World Products chose to switch to the ARP brand studs, not because we found them to necessarily be better, but to align ourselves with the hardware being utilized on our Chevy and Ford blocks. I would like to point out that over the years I have experienced failure with hardware manufactured by ARP, but grab another one and move on. I have also experienced a rod breaking or a lifter failing, all from big name brand manufacturers, but that doesn't mean the sets of parts were all defective. The point is sometimes rods break, lifters fail and bolts and studs stretch, break, threads gall, etc. It is the nature of metal objects that have been cast, poured, machined and manipulated that a small percentage will fail, regardless of who manufactured the item. If you find one defective stud that does not mean all the studs are bad. As with most manufacturers, World Products has a warranty policy. Should you find any defect in any of World Products parts or components within one year of purchase simply contact us and we will be more than happy to exchange that defective part. If you would like to change out your hardware to a complete set of ARP studs, you can purchase them from your local ARP dealer or retailer. The caps are located by ring dowels and block registers. The line bore will not be affected. The torque rating on the ARP studs remains the same. Thanks for your time, Paul
[Re: DarkSideofNY]
#782191
08/27/10 06:16 PM
08/27/10 06:16 PM
Posts: 6,295 U.S.
moparniac
U.S.
Gentlemen,
so your saying to go pound sand pretty much!
Mopar Performance
[Re: HEMIFRED]
#782193
08/27/10 06:57 PM
08/27/10 06:57 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
translation buy stock in KB and Indy. No way I buy a World block
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: DarkSideofNY]
#782195
08/27/10 07:02 PM
08/27/10 07:02 PM
Posts: 1,506 TN
SCATPACK 1
TN
Gentlemen,
I'd like to introduce myself. My name is Paul Kaufman. I have worked for World Products as a technical representative and engine builder for approximately a decade. ..... .....World Products does not manufacture studs nor do we import inexpensive hardware from China. The studs used on the Mopar iron blocks are to Mopar's engineering specs and our engineers determined those studs to be of sufficient quality for use on World Products aluminum blocks as well. These studs are not ARP. More recently World Products chose to switch to the ARP brand studs, not because we found them to necessarily be better, but to align ourselves with the hardware being utilized on our Chevy and Ford blocks. ...... If you find one defective stud that does not mean all the studs are bad. As with most manufacturers, World Products has a warranty policy. Should you find any defect in any of World Products parts or components within one year of purchase simply contact us and we will be more than happy to exchange that defective part. If you would like to change out your hardware to a complete set of ARP studs, you can purchase them from your local ARP dealer or retailer. Thanks for your time, Paul
IF you check the cheap studs provided, and those inspected by knowledgable engine builders on this site, you will read the post that stated the threads on the CHEAP Studs were scratchy. Sure sign of low budget inferior studs. It is too bad World has decided to let the studs stand and not be willing to replace them as a whole. I am REALLY GLAD I saw this post as I have been bidding on an aluminum Hemi block from World on ebay. I will not be going thru with this in light of this response from World. Such BAD Publicity could have easily been corrected by simply replacing the studs or offering, at the very least, to split the cost of replacement to a quality stud set. Just really disappointing. I wonder what there response would have been if it were a bunch of there beloved Chevy blocks that had issues. They have bent over backwards to correct the issues in the past for Chevy customers. Boy, Just disappointing! I suppose Indy or KB will get my money now.
Old Geezer Racing
[Re: DarkSideofNY]
#782196
08/27/10 07:19 PM
08/27/10 07:19 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Gentlemen,
Well put Paul,we have seen alot of issues resulting from incorrect torquing methods(torque values or wrong lubricants)as well as bad stud installation or application.We usually make the correction and move on.However even with the dowel rings that locate the main caps(similar to rod caps)the different clamping loads of different fastners would raise the concern for distortions(no mater how small) and would warrant at least checking or honing the line bore for perfect or "near" perfect alignment and fit.I would never change rod bolts(even if the same replacements) without checking or resizing the rod.May I inquire who manufactured the studs that came with the block?Just my opinion Respectfully Bob
[Re: SCATPACK 1]
#782197
08/27/10 07:24 PM
08/27/10 07:24 PM
Posts: 1,288 Oregon
sg66mopar
Well, as some of you know I just grenaded my new World blocked 572 a couple weeks ago and destroyed the block. My engine builder called me Monday and during the conversation he said the main caps had been walking and galling pretty badly. He wondered if I was running bad gas or way too much timing but that's not the case. The timing never went over 33 degrees this year and I run K&S 120 (114 octane) race gas. Now I suspect my motor had the low quality studs in it also. I can't ask him to look at them until Monday but I bet that's the deal. I need to buy a new block and now I'm wondering what to do. A lot of you here on Moparts say to go with KB but there's some serious drawbacks to that block, at least for my particular setup. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: DarkSideofNY]
#782198
08/27/10 07:26 PM
08/27/10 07:26 PM
Posts: 87 Denmark
Dart of Denmark
Denmark
Gentlemen,
What a great support!!! ![](/ubbthreads/images/graemlins/OzBBQed.gif)
[Re: SCATPACK 1]
#782199
08/27/10 07:28 PM
08/27/10 07:28 PM
Posts: 716 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
well you heard the man, if the cheap a$$ stud fails within one year while you are going down the track and you have massive damage. simply return the one broken stud and they will replace it.
Now if you were one of worlds chevy or ford customer you would never have gotten the cheap stuff.
I am sorry i every bought a World block, i should have stuck with someone that specializes in mopar engines, not someone that added it to their product line as a after thought.
Joe
Without Data, you’re just another guy with an opinion.
