Hard to crank windows '68 Charger #78205
06/22/08 08:54 AM
06/22/08 08:54 AM
MN
36viper Offline OP
36viper  Offline OP
MN
I pulled the side window out of the driver's door, lubed the mechanism, and reinstalled it...worked fair...then the gear slipped the next day as it was so tight to crank again. Also, the glass seems to drop too far when down...didn't see any lower stop in the door.
What do I need to do to get the windows to raise more easily?
Brad
Thank you Moparts for the help!
Re: Hard to crank windows '68 Charger [Re: 36viper] #78206
06/22/08 09:40 AM
06/22/08 09:40 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Hard to say with out seeing the thing in action, but I would inspect all the slides and grooves and wheels and what ever else moves in there. Check for alignment and binding or twisting in all positions. Usually an inspection of the action with the door panel and dust shield off will reveal the cause of the difficulty. Flex from worn mechanisms can cause exactly what you are describing.
Careful, your character's showing!
Re: Hard to crank windows '68 Charger [Re: mopar346] #78207
06/22/08 05:42 PM
06/22/08 05:42 PM
MN
36viper Offline OP
36viper  Offline OP
MN
Thanks, I'll take it apart again, but check it more carefully for alignment, etc..
Brad
Re: Hard to crank windows '68 Charger [Re: 36viper] #78208
06/22/08 10:21 PM
06/22/08 10:21 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Never had any luck. Installed electric-life power windows that included new regulators. Fine now.
