will Holley SD fit with air grabber #781991
08/23/10 10:34 PM
08/23/10 10:34 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
69 GTX with air grabber. Will a Holley Street Dominator intake fit?
Re: will Holley SD fit with air grabber [Re: frank] #781992
08/23/10 10:55 PM
08/23/10 10:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
As long as you don't mount a carb between them it will .... didn't we go over this months ago ???
Actually it was over a year ago you asked this ...
https://board.moparts.org/ubbthreads/show...rue#Post5130560
Re: will Holley SD fit with air grabber [Re: JohnRR] #781993
08/23/10 11:02 PM
08/23/10 11:02 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
yes. Everything got put on hold and I could not find the other post and I didn't remember the answer.
Re: will Holley SD fit with air grabber [Re: JohnRR] #781994
08/23/10 11:04 PM
08/23/10 11:04 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Worked just fine on my friends 69 RR. He did not have the air cleaner base plate, so we bought one of Paintitblack's high quality fiberglass repros. The carb neck is left a bit long(high) for trimming the height of the base plate to fit your car. It worked great!
Re: will Holley SD fit with air grabber [Re: Lee446] #781995
08/23/10 11:06 PM
08/23/10 11:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The only way to do it is to modify the air cleaner base, some people don't want to do that to original unmodified bases. I have a previously hacked 383 base that will eventually get butchered more when the time for me comes .
