3.23 or 3.55 behind 71 340 727 Auto??? #781918
08/23/10 09:52 PM
08/23/10 09:52 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
I'm finally getting my car done. I have my choice of ratios as I have one of each in my stcok pile. I'm building the car mild enough so my wife could drive it if she likes. I'm leaning toward the 3.55s so its a little quicker off the liune but I'd also like to drive at 65 mph for 40 miiles or so every once and a while. I've been out of the game since I was a teenager so I could use some knowledge on how these ratios differ. Thanks....
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: 3.23 or 3.55 behind 71 340 727 Auto??? [Re: fireeng] #781919
08/23/10 10:04 PM
08/23/10 10:04 PM
Kentucky, USA
derekeh Offline
derekeh  Offline
Kentucky, USA
I would lean towards 3.23.... but they arent that difficult to swap out. Try both!
Re: 3.23 or 3.55 behind 71 340 727 Auto??? [Re: fireeng] #781920
08/23/10 10:05 PM
08/23/10 10:05 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I like 3:55's on the street, but I wouldn't go with a tire shorter than 26" in the rear if you want to hit the highway for any great distance.
Re: 3.23 or 3.55 behind 71 340 727 Auto??? [Re: derekeh] #781921
08/23/10 10:05 PM
08/23/10 10:05 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
I didn't even consider tire size. What size tire is 26" tall?
1971 Challenger
2013 Jeep Wrangler
Re: 3.23 or 3.55 behind 71 340 727 Auto??? [Re: derekeh] #781922
08/23/10 10:06 PM
08/23/10 10:06 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
3.55, especially if going with a tire taller that 26"
Re: 3.23 or 3.55 behind 71 340 727 Auto??? [Re: fireeng] #781923
08/23/10 10:08 PM
08/23/10 10:08 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
235-60-15 are advertised as being 26" in diameter.
Re: 3.23 or 3.55 behind 71 340 727 Auto??? [Re: Neil] #781924
08/23/10 10:11 PM
08/23/10 10:11 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
I think those are in the ball park of what I would use. Do you think the 3.55s will be really winding out for that highway ride?
1971 Challenger
2013 Jeep Wrangler
Re: 3.23 or 3.55 behind 71 340 727 Auto??? [Re: fireeng] #781925
08/23/10 10:16 PM
08/23/10 10:16 PM
Outside
thedriver Offline
thedriver  Offline
Outside
1973 challenger
Dana. 4 speed. Low deck.
Re: 3.23 or 3.55 behind 71 340 727 Auto??? [Re: thedriver] #781926
08/23/10 10:24 PM
08/23/10 10:24 PM
Under My Car
Mopar_Country Offline
Under My Car
Depends on what your doing with the car, if you want a little strip time then 3.55's.
Re: 3.23 or 3.55 behind 71 340 727 Auto??? [Re: ademon] #781927
08/23/10 10:27 PM
08/23/10 10:27 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
My 440 car with 28" tires has a 3:54
My 340/727 with 26" tire has a 3:55
I think they are perfect for the street and I can tell the difference between 26-28" tires.
I drive my 340 car with 26" tires on the highway all the time.
It tachs about 5000 rpm at 120 mph with 3:55 and 26" tires. speedo says 135 but the GPS said 120mph at 4900+ rpms
Re: 3.23 or 3.55 behind 71 340 727 Auto??? [Re: Challenger 1] #781928
08/24/10 01:10 AM
08/24/10 01:10 AM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
Best ratio for street use. That is why they are hard to find used. If you were going to also race the car. I would have said 3:91's and they are even harder to find used.
Good luck and glad you are "back in the game"
Joe Sr
i
Re: 3.23 or 3.55 behind 71 340 727 Auto??? [Re: joewhite440] #781929
08/24/10 02:45 AM
08/24/10 02:45 AM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I'm running a 3.55 behind a 440/727 combo on my '69 Charger with 295/50/15 tires. I run about 3200 RPM @ 70mph. The next car I'm doing is going to have a 3.23.....
Re: 3.23 or 3.55 behind 71 340 727 Auto??? [Re: JoesMopar] #781930
08/24/10 11:55 AM
08/24/10 11:55 AM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
Thanks for the input. I am going to try the 3.55s and see how it goes.
1971 Challenger
2013 Jeep Wrangler
Re: 3.23 or 3.55 behind 71 340 727 Auto??? [Re: fireeng] #781931
08/24/10 07:51 PM
08/24/10 07:51 PM
Mass
68bb Offline
super street
68bb  Offline
super street
Mass
I put the 3.55's in my 70 dart 318 4 speed over the winter and am very pleased.Doesn't feel at all bad on the highway at 65 - 70. Had 3.23's in my 68, but I like these better.
Re: 3.23 or 3.55 behind 71 340 727 Auto??? [Re: 68bb] #781932
08/25/10 10:39 PM
08/25/10 10:39 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Have you considered an overdrive?
Any choice you make will always be a compromise.
A highway gear is high 2's and a drag gear is 4 something.
If it's a restoration or if you don't mind spinning the engine high or enjoy driving in the right lane with everything passing you, disregard.
Re: 3.23 or 3.55 behind 71 340 727 Auto??? [Re: fireeng] #781933
08/25/10 10:48 PM
08/25/10 10:48 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I have ran both 3:55/26" tires and 3:91/27" tires and I like them both with my 340/727 Challenger. I don't usually run 70+ (except WOT runs) but up to 70mph cruising speed is fine with either of these combos.
