Re: cross ram bb question:.....
[Re: moparmanof85]
#781795
08/23/10 08:38 PM
08/23/10 08:38 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
its got the high rise water pump and the heads are maybe 1-2 inches taller than standard. its an industrial, i think.
That head takes a special intake , a crossram will not bolt to them , they are no good to you for what you want to do , I assume put it in a car ???
[Re: moparmanof85]
#781801
08/23/10 10:39 PM
08/23/10 10:39 PM
JohnRR
U.S.S.A.
thought about it. its a low torque engine though. thinking truck. funny... the intake manifold gasket from a regular kit is perfect. the kit is to a 413, the valve covers are to a 400, and the exhaust manifolds are 361. weird, huh?
Ok , that I did not know, from pics of the intakes I have seen they APPEARED different , but as you said if the heads are TALLER by a couple inches the crossram is going to hit the valve covers .
[Re: moparmanof85]
#781807
08/24/10 08:18 PM
08/24/10 08:18 PM
Posts: 456 Santa Barbara, CA
HitIt
Santa Barbara, CA
New water pump housings are a dime a dozen. If you really want a crossram don't let the water pump stand in your way.
very clever dinner. appetizing food fit neatly into interesting round pie.
[Re: HitIt]
#781808
08/24/10 08:24 PM
08/24/10 08:24 PM
Posts: 15,487 Florida
scratchnfotraction
what kind of square stock pieces are on the tranz and bell housing in the back ground?? that looks as odd as the industy water pump and heads nice and orange too is that the fan spacer laying in/on the intake front in the first pic i would run it just for the kool and different factor in my truck cant be that bad of engine for a driver,deff different looking in a sea of mundane BB out there
