Re: Pros and cons of reground camshafts?
[Re: wyoming]
#781723
08/24/10 09:01 AM
08/24/10 09:01 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
you probably don't need adjustible rockers, but you may need to get new (longer) pushrods, or you could perhaps mill the heads a skoash to account for the smaller base circle
[Re: patrick]
#781724
08/24/10 10:39 AM
08/24/10 10:39 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
How much are they going to grind off the base circle ? It can't be much unless they re-heat treat the shaft and I don't think this is a common practice. I think they are limited by the depth of heat treat as to how much material they can remove. If it is much more than .010 - .015 I'd be surprised.
