Re: big block with throttle body injection????
[Re: OzHemi]
#781367
08/23/10 04:38 PM
08/23/10 04:38 PM
DaytonaTurbo
Manitoba, Canada
Will the distributor work at all? The tbi small blocks would have used a different distributor. Did the tbi small blocks still use an old-school magnetic pickup or were they a hall pickup? If it was a magnetic pickup, a distributor from a lean burn/electronic spark control car might work. A distributor with a mechanical advance definitely would not work. The computer uses the spark timing to control the injector timing so if you don't have a distributor that's working correctly, you won't get fuel or spark. I will say it's going to want to run lean all the time. During warm-up, accel and full-throttle when the computer goes into open loop(oxygen sensor ignored) the computer will default to it's programming for 360 fueling. At cruise, the o2 sensor *may* be able to cover or partially cover the extra cubes. I'm going to bet IF it runs, it will not run well. If driveability is what you want, a well-tuned thermoquad is actually quite good. Either way, good luck. I hope I'm wrong and it runs well for you.
[Re: moparmanof85]
#781371
08/23/10 05:20 PM
08/23/10 05:20 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I have had the same thought. I believe it will work just fine. The dist is a Hall Effect and the rotation isnt going to make a difference. My research said that the 360 TBI unit flows 660 CFM, it does have large throttle bores. It may need a size or 2 larger injectors but a good injector shop shoud be able to help.
I am truckless..
[Re: moparmanof85]
#781373
08/23/10 07:21 PM
08/23/10 07:21 PM
Posts: 352 Arizona
69rrgrabber
Arizona
I'm also putting together an EFI big block, a 440. It is a Holley Commander TBI 900 cfm set up. These can be had pretty cheap used on EBAY, I've seen complete used setups for $400, new they were $1600. Maybe worth a look? I like that the 4bbl throttle body is about 1 1/2 inch shorter that the stock carb so I can fit an Eddy RPM intake!
CAC
"It takes a Mopar to catch a Mopar!"
1969 Charger R/T 440
1969 Road Runner 383
1970 Cuda 440
