mechanical tach and cables - help #780581
08/22/10 06:48 PM
08/22/10 06:48 PM
USA
SSAAHemiFan Offline OP
USA
I posted here because so many of you are "veteran" racers familiar with older vintage part's.
After MANY years of steady searching I FINALLY have found all the pieces and cables for the tach "system" on my SS/AA project.
Problem is the business end of the tach cable I have is what I think they call "Jones style" has a 7/8 nut and a female square drive.
The tach I want to use is a Stewart Warner - it seems to have a 5/8 nut and would need a small male square drive on the cable end to insert into the tach.
Anyone know if there is a way to adapt these?
Tried a couple of speedo shops already and they have no idea and the newer cables just don't look correct
This stuff is before my time so I might not be using the correct terminology.
I would appreciate any info or suggestions.
Pic of cable end on left - tach end on right
Re: mechanical tach and cables - help [Re: SSAAHemiFan] #780582
08/22/10 07:02 PM
08/22/10 07:02 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Getting old just means you were smarter than some and luckier than others.
Re: mechanical tach and cables - help [Re: SSAAHemiFan] #780583
08/22/10 07:07 PM
08/22/10 07:07 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Looks like Danny has given you some great info. I still use a cable driven tach set up and like it a lot.SW 535AH tach with the Mopar tach drive distributor,and I have a vintage Accel BEI tach drive unit to use if need be.
Glad to see you're using the cable system.
Nautilus Racing-
Re: mechanical tach and cables - help [Re: Chris2581] #780584
08/22/10 07:24 PM
08/22/10 07:24 PM
USA
USA
Thanks Danny - I did contact Pegasus .. waiting to hear back - they have a adapter on there site but it is for the opposite situation I have.
Have my that they have another solution !
Here is pic of the whole thing.. you can see what I am trying to accomplish.
Re: mechanical tach and cables - help [Re: SSAAHemiFan] #780585
08/22/10 08:52 PM
08/22/10 08:52 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
you do realize that your problem comes from the fact that tach is incorrect for that set up? a 5" Jones/Stahl in the gold anodized bracket would be the correct one.
home of the
Sox and Martin Hemi Duster
Re: mechanical tach and cables - help [Re: HEMIFRED] #780586
08/22/10 09:24 PM
08/22/10 09:24 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
another ? for those in the know, which style is used to go from a mp tach drive distributor to a stewart-warner tach? thanks, dave
Re: mechanical tach and cables - help [Re: HEMIFRED] #780587
08/22/10 09:28 PM
08/22/10 09:28 PM
USA
USA
Yep, I'm stubborn and was hoping that an adapter or adapter cable could be made to work.. I'm a Sox and Martin fan and want to use a SW tach
If I can't make it work... Maybe we can make a deal Fred
Re: mechanical tach and cables - help [Re: Chris2581] #780588
08/22/10 09:33 PM
08/22/10 09:33 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Stewart Warner performance gauges distributor
http://www.speedometersolutions.com/speedometer_cable.htm
Custom Built Speedometer Cables, for any application
Mechanical Take Off Speed Sensors, for aftermarket or factory speedometers, tachometers,cruise, made to suit, any mechanical drive,custom applications are our specialty
Tachometer cables and drives, cars, trucks, cycles, tractors, airplanes, boats, heavy equipment
Autometer, VDO, Stewart Warner, SS White, Clark Bros., Syncro Start, Arthur Allen, Dixon, AC Delco, GM, Mopar, Ford Motorcraft, Datcon, Plus many more
NOS, New, Used, Rebuilt, gauges, clusters, 75 + years worth of inventory,Just ask
home of the
Re: mechanical tach and cables - help [Re: HEMIFRED] #780589
08/22/10 09:35 PM
08/22/10 09:35 PM
USA
USA
Thanks Fred.... I contacted that place also..
Re: mechanical tach and cables - help [Re: 3ddart] #780590
08/22/10 09:41 PM
08/22/10 09:41 PM
USA
USA
3ddart,
Mopar Performance used to offer the cable you need - it had a black plastic sheathing instead of a metal armor.
They come up from time to time at Mopar meets
Here's a place that I came across while looking for a solution for myself..
http://www.texasindustrialelectric.com/speedo.asp
Seem to have a bunch of SW pieces listed
Re: mechanical tach and cables - help [Re: SSAAHemiFan] #780591
08/22/10 10:00 PM
08/22/10 10:00 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
http://cgi.ebay.com/ebaymotors/Jones-Mor...em&pt=Motor
Looks like this guy will make what you need.
Re: mechanical tach and cables - help [Re: dannysbee] #780592
08/22/10 10:22 PM
08/22/10 10:22 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
thanks danny, fan & fred!!!!!
Re: mechanical tach and cables - help [Re: 3ddart] #780593
08/23/10 09:16 PM
08/23/10 09:16 PM
langley b.c. canada
don miller Offline
don miller  Offline
langley b.c. canada
I ran the same setup back in the early 80's but I'll be darned if I can remember exactly what I used-I think there were different drive ends that got crimped on the distributor end (the cable came from Stewart Warner) You might try Bob's Speedometer,1-800-592-9673, 10123 Bergin Rd. Howell, Mi 48843.
Re: mechanical tach and cables - help [Re: don miller] #780594
08/24/10 04:41 PM
08/24/10 04:41 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Located mt old tach and cable in the garage today. Is this the same as your's
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: mechanical tach and cables - help [Re: SSAAHemiFan] #780595
08/24/10 05:49 PM
08/24/10 05:49 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
I ran into that exact same issue thirty years ago, when I installed my SW mechanical tach and only had a Moroso cable.
What I did was to go to a local machine shop, left them both pieces, and they machined an adapter out of a piece of brass. As far as the end that goes into the tach, I brazed the tach end of the cable with a big clump of brass, and then took a file and filed it to fit the keyway in the distributor.
How does it work? Well, the setup is still on there and is what I use, and has been since 1974. I guess you could say it worked out.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: mechanical tach and cables - help [Re: Steve1118] #780596
08/24/10 06:09 PM
08/24/10 06:09 PM
New Jersey
Craig Offline
Craig  Offline
New Jersey
I did sorta like Steve1118, I mig welded a lump of ezgrind onto the end of the square cable key and filed it down to fit. Works great with my 30+ year old Moroso mech tach, been over 7700 rpm a few times
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
Re: mechanical tach and cables - help [Re: Craig] #780597
08/24/10 07:43 PM
08/24/10 07:43 PM
USA
USA
Thanks everyone for the help... 1 place got back to me that said they "think" they can cut the end off my cable and add the correct end but it would shorten the cable 4".
Pittsburg - I appreciate you digging out your tach and cable.... Any chance you could post a picture of the end that screws into the tach?
I would like to see exactly what it looks like , maybe I can make something like Craig and Steve mentioned.
Re: mechanical tach and cables - help [Re: SSAAHemiFan] #780598
08/24/10 08:38 PM
08/24/10 08:38 PM
PA.
"Little"John
"Little"John
PA.
If these aren't clear enough let me know.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: mechanical tach and cables - help [Re: pittsburghracer] #780599
08/24/10 08:50 PM
08/24/10 08:50 PM
PA.
"Little"John
"Little"John
PA.
Those came out terrible!!! Kinda late on a cloudy day. Let me know the angles of pictures you need and I will do a better job tomorrow.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: mechanical tach and cables - help [Re: pittsburghracer] #780600
08/25/10 11:02 AM
08/25/10 11:02 AM
USA
USA
Those will work - Thank You - I just wanted to verify the tach end was just square (no tang)
